sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Sun Sep 17, 2017 7:47 am Post subject: |
Well there could be one of two issues here. First check what files you have in the POI folder of your Camper. You should only have one PGPSW file which should be dated recently if you update weekly. If there is another one with a much older date then delete it and the problem should be solved.
If that isn't the issue then you need to look at the folder you're pointing POI loader at, there must be some old camera files in that folder. _________________ Where there's a will ... there's a way. |
cliffbrown Lifetime Member
Posted: Sun Sep 17, 2017 8:15 am Post subject: |
Thanks, I found two files on the garmin one was from 3/3/17, they where in different folders too, so I have deleted the old one and will give it a try later,
thanks again |
Kremmen Pocket GPS Verifier
Posted: Sun Sep 17, 2017 9:20 am Post subject: |
Different folders !
Does that mean it reads POI's in more than one place ? _________________ Satnav:
Car Average MPG :
Posted: Sun Sep 17, 2017 2:16 pm Post subject: |
from the last time I updated express, when I connect the Garmin to my laptop it opens two file explorers, one reads Garmin Nuvi (E:)the other reads (F
so in E I have 18 items listed, System, Garmin, POI, etc
in F I only have 3 folders in a subfolder of Garmin is POI
I deleted both files and using POI loader I have reloaded and the latest update, the file is in the E directory in POI with the campsite POIs preloaded on the unit.
strange, I have had trouble before updating the database I wonder if that is why, but how does the computer see two drives? |
Posted: Sun Sep 17, 2017 2:18 pm Post subject: |
pennys dropped there is an sd card in unit. doh! |
Posted: Sun Sep 17, 2017 3:01 pm Post subject: |
Yep, that'll do it _________________ Satnav:
Car Average MPG :
Posted: Sun Sep 17, 2017 6:39 pm Post subject: |
Kremmen wrote: | Different folders !
Does that mean it reads POI's in more than one place ? |
Nuvis will hoover up poi files wherever they are. Not sure about Drive models. _________________ Where there's a will ... there's a way. |
