Pocket GPS World :: View topic - Routing algorithms again
cottonsocks
PostPosted: Mon Sep 11, 2017 10:36 am    Post subject: Routing algorithms again Reply with quote
Here's another example of nonsensical routing choices being made by our satellite navigation devices. I have uploaded some screenshots which should be available on the following links:-
https://app.box.com/s/emupritrd2pfbe29pw7o4zvcm9smwlns
https://app.box.com/s/9oo9gnix81ixshud76vb74syn3xeah5h
https://app.box.com/s/sxus9n4d08rvn1lagi7xf8ohsl029rt7
https://app.box.com/s/iagto1cstp2dw2uqzhxwavd24di7a88l
They show the route chosen by Garmin Basecamp, the relative differences in journey times (calculated by TomTom's MyDrive route planner, but in reality the difference could be much greater if meeting vehicles coming in the opposite direction) and photographs of the sensible (main road) route and the road chosen by Garmin.
Why, after these devices have been around so long, are they still trying to send us down illogical and potentially hazardous routes like this?
Allan_whoops
PostPosted: Mon Sep 11, 2017 10:48 am    Post subject: Reply with quote
At a guess because of their classification (B) and that they will be tagged as national Speed Limit, i.e 60.
I still use my Garmin but use Mapfactor on a tablet. That has the ability to choose which type of road to use and a speed limit for each type. I have customised it to stay away from unclassified etc. However, it does cause problems if your destination is on one of those types of road.
PostPosted: Mon Sep 11, 2017 11:46 am    Post subject: Reply with quote
Not sure what settings you're using or even what point you're really trying to make but on my Garmin DriveSmart it routes along the A438 and then the B4208, seems sensible to me Very Happy
Note BaseCamp will route that way too if you select Avoid residential roads Wink
Moral here is don't always assume your satnav will route the same way as BaseCamp.
cottonsocks
PostPosted: Mon Sep 11, 2017 8:32 pm    Post subject: Reply with quote
I've changed the setting in BaseCamp and it does seems to provide better routes. Pity we can't do that direct on the sat nav (can we?).
PostPosted: Mon Sep 11, 2017 8:39 pm    Post subject: Reply with quote
Not like you can in BaseCamp but as I indicated if you try the route on your device it should route along the A road.
You can also adjust the various speeds on different classes of roads in BaseCamp. This might help you get routes more to your liking.
22.105 (30 Oct 24)
