Pocket GPS World :: View topic - Max volume on alerts
Post new topic   Reply to topic    Pocket GPS World Forum Index -> CamerAlert on Android
Davidwf
PostPosted: Sun Aug 06, 2017 8:07 am    Post subject: Max volume on alerts Reply with quote
As per title I cant seem to reduce the volume of the alerts.
Have tried all the settings I can find on phone and app
Samsung galaxy s5, android 6.0.1
marksfish
PostPosted: Sun Aug 06, 2017 8:17 am    Post subject: Reply with quote
On my S6, the volume is the buttons on the left side, the ones you would use to turn music up or down. Once activated, you can access a drop down menu for all the other volumes it has.
Mark
Davidwf
PostPosted: Sun Aug 06, 2017 9:15 am    Post subject: Reply with quote
Nope, tried that
PostPosted: Sun Aug 06, 2017 9:52 am    Post subject: Reply with quote
I made a post about that within the last month (which I solved).
What settings have you got for the audio output ?
Berisford
PostPosted: Sun Aug 06, 2017 11:24 am    Post subject: Reply with quote
In the APP setting there's 'advanced' at the bottom of the list and in there is an option to set the warning volume relative to the music/audio volume....does that not make a difference?
IanS100
PostPosted: Sun Aug 06, 2017 12:38 pm    Post subject: Reply with quote
That does not have any effect if you're listening via the phone internal speaker, only bt/car. I have exactly the same problem as the OP and have all but given up using CA because I can't reduce the uncomfortably loud sound level.
PostPosted: Sun Aug 06, 2017 3:04 pm    Post subject: Reply with quote
Take advice from Kremmen, He solved it on his setup.
Davidwf
PostPosted: Sun Aug 06, 2017 3:31 pm    Post subject: Reply with quote
Have tried all options I can find .......maybe a link to your solution please
PostPosted: Sun Aug 06, 2017 3:51 pm    Post subject: Reply with quote
My issue was actually max volume when played via BT through the car. The phones own speaker system was silent for me which I never investigated.
I'll try and find the thread.
IanS100
PostPosted: Mon Aug 07, 2017 12:43 am    Post subject: Reply with quote
I use the phone speaker not bt
Davidwf
PostPosted: Fri Aug 11, 2017 7:50 pm    Post subject: Reply with quote
No further suggestions ?
PostPosted: Fri Aug 11, 2017 7:56 pm    Post subject: Reply with quote
Several people have been complaining about this, but there has been no definite 'fix' offered by the developers.
Great app, great database, app let down by lack of support and feedback. Confused
IanS100
PostPosted: Sat Aug 12, 2017 12:44 am    Post subject: Reply with quote
Earplugs!
PostPosted: Sat Aug 12, 2017 5:14 am    Post subject: Reply with quote
Just stabbing in the dark but my phone has different sound levels for different things. Check all of them and see if one is on max.
IanS100
PostPosted: Sat Aug 12, 2017 7:05 am    Post subject: Reply with quote
Cheers, so does mine, and I've tried adjusting them all but CA seems to bypass everything in its bid to drown out everything else
Post new topic   Reply to topic    Pocket GPS World Forum Index -> CamerAlert on Android All times are GMT + 1 Hour
