aidy90 Occasional Visitor
Posted: Thu Jun 29, 2017 6:47 pm Post subject: Garmin`nuvi 52 and speed camera alerts |
Hi everyone
I hope someone may be able to help with my problem
when I load a route into my satnav the camera alerts work
However if I am just driving around without a route planned the camera alerts dont work
So if I just fancy a run out in the local countryside without planning a route then I have no alerts
Any help woyld be great
Thanks in advance
Aidy |
Kremmen Pocket GPS Verifier
![Pocket GPS Verifier Pocket GPS Verifier](modules/Forums/images/ranks/verifier.gif)
![](modules/Forums/images/avatars/4810985884fb0a2b6dedb3.gif)
Posted: Thu Jun 29, 2017 6:52 pm Post subject: |
That's a new one on me. It should produce alerts regardless.
Is this the database here or Cyclops ? _________________ Satnav:
Car Average MPG :
Posted: Thu Jun 29, 2017 6:56 pm Post subject: |
Kremmen wrote: | That's a new one on me. It should produce alerts regardless.
Is this the database here or Cyclops ? |
Its this database |
Posted: Thu Jun 29, 2017 7:12 pm Post subject: |
So it was sent to the 'device' using POILoader?
The .GPI file is on it's own in the POi folder.
Might be worth running through my spoon feed post just to check it all ties up.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=97158&highlight=spoon
If that all checks out then run through the device settings. _________________ Satnav:
Car Average MPG :
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Thu Jun 29, 2017 7:58 pm Post subject: |
New one on me too, only reason you may not get an alert is if you're well below the limit. _________________ Where there's a will ... there's a way. |
Posted: Fri Jun 30, 2017 3:59 am Post subject: |
Oh yes, forgot about Garmin AI _________________ Satnav:
Car Average MPG :
BAVC10 Lifetime Member
![](modules/Forums/images/avatars/gallery/avatar_ani_015.gif)
Posted: Fri Jun 30, 2017 6:05 pm Post subject: |
Do you get a visual alert if not an audible one? You should see the icon for the camera on the screen but won't get an audible alert (bong or user defined voice) if you are under the assigned speed. _________________ DriveLuxe 51 LMT D - Firmware 6.70
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3 |
Posted: Sat Jul 01, 2017 10:48 am Post subject: |
BAVC10 wrote: | Do you get a visual alert if not an audible one? You should see the icon for the camera on the screen but won't get an audible alert (bong or user defined voice) if you are under the assigned speed. |
Hi all thank you for your help
I re installed everything as I normally do with POI loader and all appears ok now
thanks again
Aidy 90 |
Posted: Sat Jul 01, 2017 10:51 am Post subject: |
Great ![Very Happy](modules/Forums/images/smiles/icon_biggrin.gif) _________________ Where there's a will ... there's a way. |
