stuartm Lifetime Member
![](modules/Forums/images/avatars/gallery/031.gif)
Joined: 21/03/2003 10:37:20 Posts: 116 Location: Barkham
Posted: Mon Oct 04, 2004 6:20 pm Post subject: |
1. POIs only display if you're not moving, anything over a crawl and they disappear.
2. According to the documentation if you select 'Detour' a new route should be calculated and the difference shown to you, at this point you should be given the choice to accept or reject the new route. On mine none of this happens, it just starts navigating on the new route.
3. I've had a couple of application crashes, unfortunately it's never been in a situation where I could note down the error dialog, I'll try and get the details next time. |
Venompeter Occasional Visitor
Posted: Mon Oct 04, 2004 11:37 pm Post subject: |
I have had a few crashes now too, I thought they were lack of memory but there werent many other apps running last time it did it. Will try to note it down too.
Peter |
fozzie63 Occasional Visitor
Joined: Sep 26, 2004 Posts: 41 Location: Chichester, West Sussex, UK
Posted: Mon Oct 04, 2004 11:43 pm Post subject: |
I had a major lock-up this morning whilst using CoPilot which ended up with me having to do a hard-reset. Luckily I use Sprite Backup so recovery was fairly painless, except that the backup was prior to installing CoPilot. Have finally got CoPilot to re-install (after a few false starts) but it won't activate; it says the license is already in use on another computer. So, I'm waiting to hear back from ALK.
Is it a bug or by design that the POI Alert sound and the one you get if you take a wrong turning is the horrid cow bell "dong" sound? |
Posted: Mon Oct 04, 2004 11:51 pm Post subject: |
OK got it to crash again (only a few minutes after the previous message)- It gives this message (as usual)
Alert!
Alloc 356.60kb, ProgM 412 Kb, StrgM 911.88kb
will contact ALK support
Peter |
Posted: Tue Oct 05, 2004 12:05 am Post subject: |
How about this one-
It is impossible to fill in the technical support form correctly on the european website and select Smartphone- you need to invent a load of Pocket PC details or the site wont accept your technical support request
AND it wont take an 11-digit phone number in the phone field
Peter |
Posted: Tue Oct 05, 2004 7:05 am Post subject: |
Venompeter wrote: |
Alert!
I think the important bit is the title of the dialog, something like 'GB_MinApp::AddRoute' |
Posted: Tue Oct 05, 2004 12:42 pm Post subject: |
Daft thing is you cant read it- you only see the first few letters of the message at the top of the window.
I think it must be the Pocket PC code :^)
I have seen the message you mention, but I think I've seen others, will watch for it
P |
Skippy Pocket GPS Verifier
![](modules/Forums/images/avatars/7197988194d2507f52befb.jpg)
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Tue Oct 05, 2004 1:37 pm Post subject: |
stuartm wrote: | Venompeter wrote: |
Alert!
This means out of memory, I think. I have had this happen even though I had no other programs running (checked using task manager). ![Crying or Very sad](modules/Forums/images/smiles/icon_cry.gif) |
Posted: Tue Oct 05, 2004 7:13 pm Post subject: |
Possibly, but knowing you have an error condition is not much use if you can't track where the error happened, the dialog title will at least get you to the routine where the error made it's presence known. (Which may not be where the error occurred) ![Stop it!](modules/Forums/images/smiles/custom15.gif) |
Posted: Tue Oct 05, 2004 10:37 pm Post subject: |
My half dozen crashes have all been 'out of memory' errors. I must take a pen & paper with me to capture them in full.
(Found out that the 'dong' is the default POI alert and re-routing sound). |
Posted: Tue Oct 05, 2004 11:09 pm Post subject: |
Venompeter wrote: | re: the suggestion for stopping the "welcome" noise, that seems to be aimed at Pocket PCs, I couldnt find an equivalent on the Smartphone. |
Errrm, don't know why you couldn't find it; it's the same filename in the same location. Works great on my C500 - peace at last ;)
(Just a thought - you did look in \Storage\Windows and not \Windows ??) |
Posted: Wed Oct 06, 2004 12:43 pm Post subject: |
I had a strange one last night.
When I leave work I can either go left or right, I went right, CoPilot decided I should go left, at the end of the road is a typical 4 exit roundabout, CoPilot instructed me to take the first exit rather than the 4th and the arrow on the display turned left and then crossed over itself to go back to the right. |
Posted: Thu Oct 07, 2004 3:31 pm Post subject: |
stuartm wrote: | 1. POIs only display if you're not moving, anything over a crawl and they disappear.
I've spoken to ALK about this and apparently that's what it's meant to do, personally I'd rather see them. If they already have the code in there to toggle visibility of POI then I'd prefer it to be user selectable. |
Posted: Thu Oct 07, 2004 7:12 pm Post subject: |
That seems strange. I did wonder why I hardly ever saw the POIs! I agree with you; it would be useful to be able to toggle them on and off.
Safety camera POIs seem to be very hit and miss. On my route to work and back, sometimes they alert, sometimes they don't. I've tried different alerting distances but can't seem to get reliable, consistent warnings. |
Posted: Thu Oct 07, 2004 9:34 pm Post subject: |
I've seen some oddity with POI alerting. On my route to the supermarket there are two speed cameras, one on each side of the road, I get a warning on my way to the supermarket but not on the way back, both cameras are in the database. |
