Pocket GPS World :: View topic - iGo 8.3 skins and problems
malc_b
PostPosted: Mon Jun 26, 2017 10:53 am    Post subject: iGo 8.3 skins and problems Reply with quote
I've got a new sat nav for my birthday to replacing my old one. I choose a cheap 5in winCE model as I new I could always fall back to running the 8.3.2 iGo on my old sat nav. I like iGo and the fact I can skin it.
My new sat nav came with iGo 8.3.4 and a lot of skins, Fab1.2, Riks, etc. most of which just crash with out of memory /layer expected. Anyone know what causes this error and is there a fix?
Anyone know of a source of 8.3 skins? Most links seem old and no longer work. I have some skins but this sat nav has more screen area so can afford to have larger items. I like GJ6 skin except I'd like the bottom bar a touch bigger and the compass is not nice (Or is there a good guide on how to edit skins?).
PostPosted: Mon Jun 26, 2017 6:08 pm    Post subject: Re: iGo 8.3 skins and problems Reply with quote
That error is caused by some idiot just loading a bunch of skins on it when they don't know what they are doing and don't put all the stuff on it. This can happen if someone had edited the data.zip file and put a layer in it that is required by his skin, but that data.zip has not been provided. Debugging will tell you the name of the missing layer. But where to get it from ??????
A layer is pretty much anything on the screen such a speed camera alerts etc.
That's about par for th course with iGo8 these days
I couldn't find one. It takes quite a bit of time to learn the 'language' and syntax, but it is possible to re-scale an existing skin to a higher re4s screen if you know what you are doing. But it ain't easy.
malc_b
PostPosted: Mon Jun 26, 2017 6:43 pm    Post subject: Reply with quote
BTW the the error is (greater than)/layer(less than) expected and out memory, not either/or as it could be read. I had a poke about but I could find a missing (greater than)/layer(less than).
I've tried a few data.zip and branding.zip. My branding.zip from my old sat nav has icons in it which my poi need. I guess I have saved a poi and given it an icon which was in branding.zip. The new iGo just seems to have the start up screens in branding which would seem more sensible.
PostPosted: Tue Jun 27, 2017 12:51 pm    Post subject: Reply with quote
I think you have 'greater than' and 'less than' the wrong way around.
If you have then that would be standard markup - the gt/lt surrounding the tag and the / saying it's the end of the tag. I.e. the error is saying that there's a start tag for {layer} but not the ending tag of {/layer}
Are there any opening {layer} tags? If not then what if you simply add an empty layer - {layer}{/layer} ?
I have no idea how they do their skins so I'm just clutching at straws really.
malc_b
PostPosted: Tue Jun 27, 2017 4:29 pm    Post subject: Reply with quote
DUH, yes wrong way round is gt and lt.
I've done a search in files for layer and then looked down the files but I can't spot a missing closing tag. I think the error is wrong though and not actually tell me the real problem. This sat nav came with 6 skins which all fail with the same error. It would seem odd if all 6 had missed a closing layer tag so I think it is something else missing, or they are skins for a different iGo or later version.
PostPosted: Tue Jun 27, 2017 4:35 pm    Post subject: Reply with quote
Does that mean that you can't get it working at all because of the errors?
malc_b
PostPosted: Tue Jun 27, 2017 4:56 pm    Post subject: Reply with quote
The "bad" skins stop iGo from working, it crashes. iGo works ok with "good" skins and default skin.
Actually I found that 8.3.4 had a problem with a specific post code which worked ok in my 8.3.2. I tried maps and sys.txt and eventually tried swapping juts the iGo exe. 8.3.2 worked (as did it 8.3.5 I tried) but put 8.3.4 exe back and with this post code it crashed. It was a post code that didn't come up with a region as most do. Other post codes worked ok with 8.3.4. I think 8.3.4 has a memory leak with certain post codes that wasn't in 8.3.2 and that they fixed in 8.3.5
23.061 (04 Jun 25)
