Pocket GPS World :: View topic - Loading a pre- arranged route
marksfish
PostPosted: Wed May 17, 2017 7:58 pm    Post subject: Loading a pre- arranged route Reply with quote
I am going on a car rally at the weekend. The organisers have sent over a gpx file with the route on. How do I load that to my Garmin please?
Mark
marksfish
PostPosted: Wed May 17, 2017 8:05 pm    Post subject: Reply with quote
Should have Googled first Embarassed
So now I have loaded the two gpx files to the Garmin folder on my satnav. Google doesn't help me to use the route on these files now.
PostPosted: Wed May 17, 2017 8:34 pm    Post subject: Reply with quote
You need to put them in the GPX folder. Assuming you have a nuvi with trip planner they should then appear there.
marksfish
PostPosted: Wed May 17, 2017 8:35 pm    Post subject: Reply with quote
Me again.
I have since found the route, hidden in Apps/ Trip Planner Smile . Both trips are called Waypoint, so I can't differentiate them without opening the file Sad. All of the waypoints are listed separately. If I select "Go", I am asked to "Select Next Destination". Can I not set it to navigate the entire route taking in the waypoints instead of having to interact at every one?
PostPosted: Wed May 17, 2017 8:43 pm    Post subject: Reply with quote
When asked to select a point and provided you have a recent nuvi once you reach the first point you select you will automatically be directed to the next and so on ...
You can rename the routes in trip planner.
PostPosted: Thu May 18, 2017 4:44 am    Post subject: Reply with quote
I'm doing a similar thing on Sunday.
I planned a route in Basecamp then shaped it to be the way I want to go (afs).
I've activated a silent .vpm
The object of the exercise is to have the Garmin display traffic for the whole route. Silent voice pack because I use the car Nav for the directions and any detours.
First time I've done it with a pre loaded route so will be interesting.
Satnav:
Car Average MPG :
marksfish
PostPosted: Thu May 18, 2017 5:10 pm    Post subject: Reply with quote
I have now moved the files from the Garmin folder to the GPX folder. Still shows the same in Trip Planner. I am travelling as part of a team, so will only really need it if I get lost from the group Very Happy
Fingers crossed.
Mark
PostPosted: Thu May 18, 2017 7:19 pm    Post subject: Reply with quote
The ALWAYS happens when you don't want it to.
marksfish
PostPosted: Mon May 22, 2017 5:41 pm    Post subject: Reply with quote
Back from my trip, luckily I didn't get separated as there was an issue. There were quite a few waypoints in the file (110kms route). The problem I had was that the route didn't compute using roads, it just plotted a straight line between each of them Confused . Not sure if it was me or the way the file was constructed?
Mark
PostPosted: Mon May 22, 2017 5:50 pm    Post subject: Reply with quote
Probably an issue with the GPX file. Did you ever recalculate it? I suspect it was created using a map different to yours so if you didn't recalculate on your map it would have been straight lines.
marksfish
PostPosted: Mon May 22, 2017 7:18 pm    Post subject: Reply with quote
It was my first time using these files, I didn't know about re- calculating it, or how to do it. I shall have to have a look when I turn it on.
Mark
22.062 (12 Jun 24)
