Pocket GPS World :: View topic - Mercedes MY17 Garmin Map Pilot - Alerts in Chinese?
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Schouten
PostPosted: Sat May 13, 2017 9:47 am    Post subject: Reply with quote
@ stephenbeck as M8TJT said - yes I solved it by having to delete 3 extra font files as per my earlier post - but only for v8 maps.
i don't know if you have to delete the font files if you follow the processes and/or macro's detailed in this and other threads by for example Kremmen, pbridgeman, and Nemesis1 which modify the basic file before using POI loader. I haven't got that far yet.
Perhaps someone could clarify?
Terry
PostPosted: Sat May 13, 2017 10:32 am    Post subject: Reply with quote
The problem is that this thread has wandered way off the original topic of Chinese characters. Very Happy
Nemesis1
PostPosted: Sun May 14, 2017 11:02 am    Post subject: Reply with quote
Still all the same for me.
95% alerts, 30% icons.
Nemesis1
PostPosted: Mon May 15, 2017 8:14 am    Post subject: Reply with quote
Is there any chance that a standard Garmin SD card will run on the MB system do we think?
Schouten
PostPosted: Mon May 15, 2017 8:47 am    Post subject: Reply with quote
I don't think it would. Isn't the MB SD card linked to the vehicle via the VIN. I know when I've updated the map and/or the software there's a verification page that comes up when I reinsert it into the car confirming it's for use with that vehicle.
That said, I know on a well known auction site "genuine" MB Garmin cards are for sale which allegedly can be registered to the car as they are unused.
I guess you'd need to look at the files on the Garmin card and compare what's different to the MB one perhaps?
I suspect as someone else posted that the processing power or memory capacity of the MB kit is not up to handling much above what it's designed for. This might explain why notification results are variable depending on what else it's trying to do i.e navigate, manage traffic, display poi's make announcements etc.
Just a thought!
stephenbeck
PostPosted: Wed May 31, 2017 1:28 am    Post subject: Chinese writing in banner Mercedes Garmen Map Pilot SD Card Reply with quote
Thank you very much for your solution below. This worked perfectly on my system which now likewise gives the camera icon on the extreme left and the distance on the extreme right on the red banner that appears at the top of the screen. Bongs are pretty consistent overall on my system.
Schouten wrote:
After upgrading to V8 yesterday I like everyone else had the return of the Chinese (or other Eastern fonts) in the camera bar. After two afternoons of trial and error I've managed to get rid of them by deleting these 3 additional font files
006-D4436-02.bin
006-D4436-03.bin
006-D4436-06.bin
as well as the original ones we had to delete i.e.
006-D0952-01.bin
006-D0952-02.bin
006-D0952-03.bin
It seems to make no difference to anything else so far but I've only tried it on the simulated route settings and not on an actual "live route"
The display now shows the camera icon on the extreme left and the distance on the extreme right. Bongs are intermittent as ever.
Hope this helps.
Terry
Schouten
PostPosted: Wed May 31, 2017 11:14 am    Post subject: Reply with quote
@stephenbeck. Glad it worked.
Incidentally I followed npr's instructions on page 4 of this thread to add the icons and warnings and it works fine. I don't get any specific camera detail in the banner just the icon and distance but it seems pretty reliable and accurate.
PostPosted: Wed May 31, 2017 3:57 pm    Post subject: Reply with quote
You could also use Kremmen's program (also on page 4) to do all the fiddly bits for you.
Kremmen wrote:
What I like to see is one sample CSV line that has been manually tweaked that has been posted as partially working.
Can you oblige?
PostPosted: Wed May 31, 2017 5:56 pm    Post subject: Reply with quote
The work I did with Nemesis some time ago did generate camera info in the banner, but, the text fed into the GPI had to be upper case.
I've asked a few times but .......
PostPosted: Thu Jun 01, 2017 7:43 am    Post subject: Reply with quote
"I have been wasting my breath" (so far). There, that finished that for you K.
PostPosted: Thu Jun 01, 2017 8:34 am    Post subject: Reply with quote
Not Worthy
dpa117
PostPosted: Sun Nov 19, 2017 5:51 pm    Post subject: 44 44 icons bmp Reply with quote
Hi, does anyone have copies of the high res bmp icons? I only seem to have the 22 22.
Rgds
npr
PostPosted: Sun Nov 19, 2017 10:35 pm    Post subject: Reply with quote
You'll find the 44x44 icons here:
http://www.pocketgpsworld.com/speed-camera-icons.php
dpa117
PostPosted: Wed Nov 22, 2017 8:33 am    Post subject: Reply with quote
thanks npr
Schouten
PostPosted: Tue May 22, 2018 1:20 pm    Post subject: Reply with quote
I've been successfully using the method suggested by npr on page 5 of this thread for some time until recently. Everything has worked fine until the last couple of times. The camera icons no longer display correctly, I just get a white box similar to the "built in" icons for fuel or food etc, with a magenta block in one corner.
Checking the POI loader before compiling the .gpi file it seems not to select the .bmp files i.e. gat.bmp, specs.bmp etc. only the corresponding .csv files are selected, .bmp's are greyed out. I've confirmed this by not including the .bmp files in the source folder and the result is the same. I've tried 22x22 and 44x44 icon sizes.
I've tried this on MAC and Windows machines with the same result.
Anyone any ideas please?
Page 7 of 9
23.054 (28 May 25)
