Davidwf Regular Visitor
Posted: Fri Mar 03, 2017 1:15 am Post subject: crashes on launch |
Have been using the Android app for a couple of years now with no problems.....now it crashes on launch.
I have un / re-installed the app and even done a complete factory reset and format of my SD card but the problem continues.
Could it be a recent Android update ?
Phone is Moto G 2nd gen running Android 6.0
I have already raised a support ticket and sent crash logs in
Am I the only one with this problem ??? |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15146 Location: Bradford, West Yorkshire
Posted: Fri Mar 03, 2017 11:42 am Post subject: Re: crashes on launch |
Have you moved it to the SD card? If so then move it back to internal storage and it will work.
MaFt |
Posted: Fri Mar 03, 2017 1:38 pm Post subject: |
I have, I did, and no it still doesn't work .... but the latest version of Android treats the SD card as internal storage anyway |
Posted: Fri Mar 03, 2017 4:13 pm Post subject: |
An SD card used as 'internal storage' in Marshmallow and later is still technically different from actual internal storage. It's been known to cause problems and I've seen it first hand on the HTC 10 in Marshmallow. Even with the SD Card formatted as internal storage, the app simply refused to load. Moved back to actual internal storage and it was fine.
But if you've tried that then I'm a bit stuck for what to suggest :/
Actually, is it on 6.0 or 6.0.1? I'm sure a while back we had issues on some devices running 6.0 but these were resolved once 6.0.1 was released for those devices. |
Posted: Fri Mar 03, 2017 6:29 pm Post subject: SORTED :)_ |
well, my flabber is ghasted.....I moved it to internal storage (i.e. PROPER internal storage and it launched OK
Thanks for your help on that - maybe the support guys should be made aware
for the record my phone runs 6.0 and there are no later updates
thanks again |
Posted: Sat Mar 04, 2017 10:55 pm Post subject: |
Yeah, I should add it to the CamerAlert manual too...!
Thanks for confirming it worked though :D |
molerat Lifetime Member
Joined: Jul 06, 2007 Posts: 202 Location: Very North of the Border
Posted: Sat Mar 11, 2017 5:56 pm Post subject: |
Came on here to look for an answer to the same
Running on 2 Android tablets with app on SD, works fine on one (5.0.1) but crashes on the other (6.0) which confused me _________________ Garmin Drive 51LMT-S EU
(TT One V3 512MB + RDS TMC UK&RoI v1005 now retired, dead due to withdrawal of manufacturer support) |
Posted: Mon Mar 13, 2017 11:31 am Post subject: |
molerat wrote: | Came on here to look for an answer to the same
Running on 2 Android tablets with app on SD, works fine on one (5.0.1) but crashes on the other (6.0) which confused me |
Has moving it to the proper internal storage fixed the issue on the Marshmallow tablet? |
nickjd Lifetime Member
Posted: Fri Mar 17, 2017 12:37 am Post subject: |
I have similar issue with a Vodafone Smart Ultra 6 android phone. Cameralert had been working perfectly on it for over a year until recently when I updated it to Marshmallow 6.0.1. The app now crashes on launch every time and reinstalling it hasn't solved it.
Although the phone has provision for an SD card I have never installed one, so I assume (I'm not very tech savvy) that the app must be installed in "proper" internal storage.
Any thoughts on a solution please? |
grillphil Occasional Visitor
Joined: Apr 11, 2007 Posts: 42 Location: Waltham Cross, Herts.
Posted: Mon Mar 20, 2017 9:54 am Post subject: |
Cheers chaps. Read this and it sorted my problems too with a HTC One M8 |
Kremmen Pocket GPS Verifier
Posted: Mon Mar 20, 2017 10:01 am Post subject: |
I've heard of other apps with 6.0.1 issues.
Not spotted what the actual reason or fix is though. _________________ Satnav:
Car Average MPG :
abre Occasional Visitor
Joined: Jan 30, 2013 Posts: 45 Location: Saddleworth, Yorkshire :o)
Posted: Tue Mar 21, 2017 11:29 pm Post subject: |
I'm no expert, but was involved in developing a Movie download app for Android devices... The biggest issue we had was device type vs OS version and the icing on the cake was any manufacturer UI overlay tweaks applied to the OS which wreaked havoc on random builds of our app.
Also certain manufacturers devices were more prone to issues than others... Sony and Blackberry being particular pains in the .... on so many levels.
I'm an iPhone user and I was astounded by the lack of consistency across the OS version point releases.
We had to restrict the specified OS version build for our app for release to ensure it worked at launch!
You guys have identified here that a point upgrade of OS is problematic and this does need to be kept in mind when an app stops working as expected after doing an innocuous OS point upgrade!
All the best... |
Posted: Wed Mar 22, 2017 11:54 am Post subject: |
A few phones had issues with the app when running 6.0.1 however after the 6.1 update it was all working again.
I'm not sure we ever goto to the bottom of it though :/ |
Yiam Occasional Visitor
Posted: Tue Apr 04, 2017 10:19 pm Post subject: Crashes are normal now |
Lately I find that CamerAlert crashes with monotonous regularity, I think it's getting to the point of being unusable. I suspect that iOS gets the development money and Android is the poor relation. Sad as I've been a user for too many years to remember now but I see an end coming soon. |
Posted: Wed Apr 05, 2017 11:46 am Post subject: Re: Crashes are normal now |
Yiam wrote: | Lately I find that CamerAlert crashes with monotonous regularity, I think it's getting to the point of being unusable. I suspect that iOS gets the development money and Android is the poor relation. Sad as I've been a user for too many years to remember now but I see an end coming soon. |
You suspect wrong.
What device are you using and are you submitting the crash logs?
MaFt |
