walkerx Lifetime Member
Joined: Oct 21, 2009 Posts: 493 Location: South Yorkshire
Posted: Thu Jan 12, 2017 9:42 pm Post subject: |
i power off most times
i noticed today the mytrends was not offered, and when checking history noticed it only recorded 6miles for yesterday instead of 40+ miles
i've performed power off reset so will see, if that no good then will backup favourites and try full master reset |
Daggers Lifetime Member
![](modules/Forums/images/avatars/gallery/pyramid.jpg)
Joined: Jun 20, 2005 Posts: 1096 Location: Solihull, UK
Posted: Thu Jan 12, 2017 10:24 pm Post subject: |
Ta - I thought there must be! _________________ Garmin DriveSmart 50 LMT-D |
Kremmen Pocket GPS Verifier
![Pocket GPS Verifier Pocket GPS Verifier](modules/Forums/images/ranks/verifier.gif)
![](modules/Forums/images/avatars/4810985884fb0a2b6dedb3.gif)
Posted: Fri Jan 13, 2017 5:43 am Post subject: |
If it's a map error, as you said, then no amount or hard resets ......... _________________ Satnav:
Car Average MPG :
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Fri Jan 13, 2017 7:37 am Post subject: |
Yes but he appears to have other issues too ... _________________ Where there's a will ... there's a way. |
Posted: Fri Jan 13, 2017 9:13 am Post subject: |
I've updated last night and done the power-off reset, so will see how it goes
I have noticed it losing GPS in the same location in Leeds around Hunslet (I assume it loses it as the bar along top goes all grey), I'm going to try and see which spot it actually disappears at, but it always reactivates in exactly the same spot, but wouldn't think driving under a single flyover would cause it to drop the signal. |
Posted: Fri Jan 13, 2017 9:41 am Post subject: |
Hmmm. Never seen that so unsure what a grey bar means? Have to pay attention next time I'm in a tunnel ![Very Happy](modules/Forums/images/smiles/icon_biggrin.gif) _________________ Where there's a will ... there's a way. |
Posted: Fri Jan 13, 2017 1:15 pm Post subject: |
yeh the corner bit which shows the turn and the notification area for alerts goes grey - i'll try to remember to check it tonight |
Posted: Fri Jan 13, 2017 1:20 pm Post subject: |
I wonder if these latest units are super sensitive, improved gps, so as well as getting a good signal it knows when it hasn't got one.
Centre of the house should do the same. _________________ Satnav:
Car Average MPG :
M8TJT The Other Tired Old Man
![The Other Tired Old Man The Other Tired Old Man](modules/Forums/images/ranks/verifier.gif)
![](http://maft.co.uk/avatars/m8tjt.jpg)
Posted: Fri Jan 13, 2017 4:52 pm Post subject: |
I find the Garmin sat receiver a bit slow to get a lock on. My Samsung phone is nearly instant. Just tried it indoors and it took about 6 seconds and outside is much quicker, whereas my Garmin really struggles to get a lock indoors at all. Mind you, who uses a satnav indoors? But it would be more convenient if it got a lock so that you could do stuff indoors without having to poke around trying to get the GPS sim on. |
Posted: Fri Jan 13, 2017 4:58 pm Post subject: |
Yes, phones can be a tad quicker as most use A-GPS or an equivalent, so use phone masts to give them an initial 'quick fix' while waiting for an exact fix from the satellites. Garmin GPS don't have that ability and if you switch them on some distance from where they were last switched off it can take a few moments for them to 'lock on'. _________________ Where there's a will ... there's a way. |
Posted: Fri Jan 13, 2017 7:18 pm Post subject: |
checked tonight and done it in the same spot at the lights on a639 at point where you go under the flyover to head towards the m621 - it then comes back blue when you reach the section to go east/west - when checked the signal the bars were green |
Posted: Wed Jan 18, 2017 6:05 pm Post subject: |
spoke to Garmin today regarding mytrends and performed a master reset sop will see if it starts working.
also been advised that even if connect using smartlink the system uses both DAB and Smartlink for traffic, even though shows only Smartlink. |
Posted: Wed Jan 18, 2017 6:29 pm Post subject: |
I'd be surprised if it did use the cable and Smartlink together. What does the traffic 'provider' say. _________________ Satnav:
Car Average MPG :
Posted: Wed Jan 18, 2017 7:55 pm Post subject: |
Kremmen wrote: | I'd be surprised if it did use the cable and Smartlink together. What does the traffic 'provider' say. |
It shows up smartlink and can't change to any other provider |
Posted: Mon Jan 23, 2017 8:13 pm Post subject: |
got official confirmation from garmin and the smartlink does override the built-in dab - only way to prevent this is not to use the smartlink features or notifications |
