Pocket GPS World :: View topic - Garmin DEM map
Garmin DEM map
PostPosted: Sun Jan 22, 2017 10:44 am    Post subject: Garmin DEM map Reply with quote
For anyone who has lost the DEM map it's now available from http://www.garminservice.de/downloads/basemap/DEM/gmapdem.img
Note this is only aimed at those models that previously had a DEM map which a map update has removed. It may or may not work on other models.
In all cases it needs to be placed in the hidden .system folder.
PostPosted: Sun Jan 22, 2017 11:59 am    Post subject: Reply with quote
I've grabbed it so I can put it on DropBox alongside the Converter.
Just in case they pull it.
Satnav:
Car Average MPG :
MichaelCahill
PostPosted: Sun Jan 22, 2017 3:47 pm    Post subject: Reply with quote
When I download and try to open, it tells me that the disc image file is corrupted.
Any idea what this might mean?
pcaouolte
PostPosted: Sun Jan 22, 2017 3:56 pm    Post subject: Reply with quote
It should be placed in the .system file on the Garmin device. It can't be opened using a PC.
Paul
PostPosted: Sun Jan 22, 2017 4:05 pm    Post subject: Reply with quote
Plus, you will need to temporarily enable Windows hidden and system files to see where it needs to go.
The same procedure as you 'should' be doing to perform a complete device backup when you first get it.
Satnav:
Car Average MPG :
PostPosted: Sun Jan 22, 2017 4:08 pm    Post subject: Reply with quote
Definitely worked here so should be fine Very Happy
PostPosted: Sun Jan 22, 2017 4:41 pm    Post subject: Reply with quote
And in answer to the question "Does it work on a 2569 or 2699?" the answer is No.
BAVC10
PostPosted: Sun Jan 29, 2017 12:20 pm    Post subject: Reply with quote
Whilst not linked to the missing DEM files has anyone noticed that Garmin has moved away from the Worldwide AutoRoute DEM Basemap NR5.01 provided by the National Oceanic and Atmospheric Administration?
They've used this for many years but the latest DRiveLuxe50 I purchased now uses Basemap NR2.00 instead of the file mentioned above (yet an earlier DriveLuxe50 has NR5.01).
Somewhat confusingly, two 'newer' (manufacturing dates) Drive50 World Traveller editions still use the NR5.01 file.
Anyone able to shed any light on the changes.
DriveLuxe 51 LMT D - Firmware 6.70
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3
