jlw Frequent Visitor
Joined: May 10, 2004 Posts: 402 Location: South Sweden
Posted: Sat Oct 02, 2004 3:01 pm Post subject: Belkin F8T001_v2 - Hate MSI BToe |
I hate Msi BToe. Cant make it working with sp2! Have tryd every singel driver. Its just cant find the device. XP finds it via the build in support. Cant make the MSI program to work and then make a serial connection...
Is the Belkin F8T001_v2 better? Well, its seems to be better. Very good revies in swedish press. and its cheap.
Anyone who have it working without problem with sp2?`
Regards! _________________ Ipaq 2210 (rom 1.10)
Fortuna Clip-On
CF: Kingston Elite Pro 512 MB
CF: Lexar 256 MB
Poporta Alu-Case |
Dave Frequent Visitor
Posted: Sat Oct 02, 2004 4:40 pm Post subject: |
My gut feeling is if you still can't get the MSI BToe to work on your PC you are going to have the same problem with nearly any BT adapter, because it's going to be interfacing with the same BT stack and DLL's that you have on your PC.
I have the BToe working fine on a number of XPSP2 machines here without a problem, so like I've said in the past, I think you've got some problems with either the registry or mixed DLL versions.
It maybe safer to do a wipe down of XP and start from fresh. It's not a nice thing to do, but if you're having problems now, I would think you're going to continue to have the same problems no matter what BT dongle you go for. |
Posted: Sat Oct 02, 2004 4:51 pm Post subject: |
Dave wrote: | My gut feeling is if you still can't get the MSI BToe to work on your PC you are going to have the same problem with nearly any BT adapter, because it's going to be interfacing with the same BT stack and DLL's that you have on your PC.
have already done that!
Have tested it on my other comp to with sp2..
dont work _________________ Ipaq 2210 (rom 1.10)
Fortuna Clip-On
CF: Lexar 256 MB
Poporta Alu-Case |
