Pocket GPS World :: View topic - Garmin CSV to GPX Converter
Goto page Previous  1, 2, 3 ... 38, 39, 40 ... 73, 74, 75  Next
Oldboy
PostPosted: Sat Jan 07, 2017 3:22 pm    Post subject: Reply with quote
I don't know if this helps.
www.tenforums.com/tutorial/3436-run-administrator-windows-10-a.html
Option Ten looks as if it might fit the bill.
TT Via 135 App 12.075: Europe Map v1135
PostPosted: Sat Jan 07, 2017 4:44 pm    Post subject: Reply with quote
I'll have a look on mine, but, Clickonce apps are designed to not put anything into Program Files or the Registry so I can guess I won't find anywhere to set that flag.
What may be the best temporary solution is to provide the M8 supplied workaround, with pictures. It's a bit of a faff but works.
I'm hoping that a shortcut can be created once and continue to work when a new version is installed.
I've posted on TechNet to see if anyone has any bright ideas.
PostPosted: Sat Jan 07, 2017 7:35 pm    Post subject: Reply with quote
Problem with option 10 is that the path to the exe changes per installation. On my lappy it's:
C:\Users\Trev\AppData\Local\Apps\2.0\N27301Y0.Z4G\68XGXOC5.O70\csvt..tion_5c04913408266626_07e0.000c_47f218bd032fdf76
and on my main computer it's:
C:\Users\trev_000\AppData\Local\Apps\2.0\5H6AXE37.WQO\HVYP8GCX.6XW\csvt..tion_5c04913408266626_07e1.0001_b0b769fed68abbf2
Not very user friendly.
But if you make a shortcut from the exe, and it's fine, but a lot of faffing around when it should 'just work'.
I've got v51 on my lappy at the mo, so I'll install v52 later and see if the shortcut to the exe still works.
NO it doesn't. And you have to set the new shortcut properties to 'Shortcut' ~ 'Advanced' ~ 'Run as administrator'
PostPosted: Sun Jan 08, 2017 6:55 am    Post subject: Reply with quote
Trev
As a test, I'll send you my /2.0/ folder structure from Win7, and my desktop shortcut.
These have been created by Win7 and work on Win7.
Once in place on your PC via a copy/paste that will determine whether it's a Win10 'setup' issue or a Win10 'run' issue.
PostPosted: Sun Jan 08, 2017 10:42 am    Post subject: Reply with quote
We will have to talk on that one K. I'll give you a bell later.
PostPosted: Sun Jan 08, 2017 3:20 pm    Post subject: Reply with quote
Win10 temporary solution found, testing, thanks M
PostPosted: Sun Jan 08, 2017 3:40 pm    Post subject: Reply with quote
Post amended - Win10 issue solved.
PostPosted: Sun Jan 08, 2017 5:45 pm    Post subject: Reply with quote
On Win 10, there is an alternative to Run as administrator in Properties. On the shortcut tab, you can click the Advanced link just below the centre right and select Run as administrator there.
Either method works, and depending on your UAC settings you will get the UAC popup to allow you to run the program.
@Kremmen.
You need to update the version number in post #1 and perhaps add a pointer to the above for W10 users.
Just tried it with a fresh d/l and working fine. Just the usual UAC 'warning'.
PostPosted: Sun Jan 08, 2017 7:00 pm    Post subject: Reply with quote
Done (and I should be)
PostPosted: Tue Jan 10, 2017 2:02 pm    Post subject: Reply with quote
The issue with Microsoft Clickonce and Win10 has been solved.
My thanks to M8TJT who has downloaded and tested umpteen versions whilst we battled to get to the bottom of the issue. (and has been awarded the silver medal)
Therefore the latest version 2017.01.10.56 is here:
https://www.dropbox.com/s/4kpnpbwlk6k2e78/CSV%20to%20GPX%20Installer.zip?dl=0
Also, move the updated .htm and .pdf help files to your Working Directory.
PostPosted: Tue Jan 10, 2017 2:11 pm    Post subject: Reply with quote
What I want to know is what kind of programmer tries to write all kinds of junk to the user's C: root anyway? If I only get the silver, the wooden spoon should go to Kremmen.Shocked
Now get the Direction converter sorted K.Rolling Eyes
On a serious not, I have been happy to get it sorted for W10 users. Gold to Kremmen.
Users cannot write a file to the root of the C: drive in W10 (and we suspect W8 as well) even if their account is set as administrator. Users can create folders in C:root and then write to them willy nilly.
PostPosted: Tue Jan 10, 2017 2:40 pm    Post subject: Reply with quote
Well now you two have finished playing I'll give it a go Wink
Allan_whoops
PostPosted: Tue Jan 10, 2017 2:49 pm    Post subject: Reply with quote
Many thanks to both of you for all your efforts on this. It is much appreciated.
PostPosted: Tue Jan 10, 2017 2:52 pm    Post subject: Reply with quote
Laughing
What was good was finding a dozen or so 'same problem' posts over the net with Win10 (and Win8) v Clickonce but no real solutions.
We have Very Happy
It's a Microsoft blunder. Their statement that Clickonce applications will raise the user privileges when required isn't true under some circumstances.
Found and fixed.
dales
PostPosted: Tue Jan 10, 2017 2:55 pm    Post subject: Reply with quote
But it seems to be working just fine, doesn't it?
Dales
nuvi 2599LMT-D, oregon 700, basecamp, memory-map.
Page 39 of 75
22.105 (30 Oct 24)
