Allan_whoops Frequent Visitor
Posted: Fri Jan 06, 2017 8:05 am Post subject: |
I have the same problem. I did a clean install of the latest version and nothing happens when I click on the icon. I uninstalled it and went back to the previous version which works fine. |
Kremmen Pocket GPS Verifier
![Pocket GPS Verifier Pocket GPS Verifier](modules/Forums/images/ranks/verifier.gif)
![](modules/Forums/images/avatars/4810985884fb0a2b6dedb3.gif)
Posted: Fri Jan 06, 2017 9:06 am Post subject: |
Interesting
Did you have both the Setup and Setup_52 files ?
I'm going back to the basic Setup.exe for the beta that M8 will get today, that is the only thing that has changed. I did that because of a suggestion that the version number isn't obvious before install. I'm going to use a text file instead.
All still working for me using the _52 file though.
If anyone want's to give the beta a shot then:
https://www.dropbox.com/s/e95y1lakvdn92i0/CSV%20to%20GPX%20Installer.zip?dl=0
Beta Instructions:
In the BMP and WAV folders are some new ones that need to go into your Working Folder:
The option to include or exclude the 'unverified' has gone. They weren't unverified but cameras with no speed associated and should be included with a suitable warning.
Note: With no speed the proximity cannot be accurately set so they will all be associated with what you have set your 60mph cameras at. _________________ Satnav:
Car Average MPG :
Posted: Fri Jan 06, 2017 9:15 am Post subject: |
Just Setup_v51.exe |
Posted: Fri Jan 06, 2017 10:08 am Post subject: |
I'm concerned now because that's 2.
The beta will prove or disprove.
..... Just installed beta v53 on another Win7 PC that's never had the Converter on it and it's fine. _________________ Satnav:
Car Average MPG :
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4458 Location: West Sussex
Posted: Fri Jan 06, 2017 11:10 am Post subject: |
Waiting with baited breath ... I've expunged every remnant of the convertors and speed cams from my system to see if when I load up the new version the BaseCamp issue is sorted ![Very Happy](modules/Forums/images/smiles/icon_biggrin.gif) _________________ Where there's a will ... there's a way. |
Posted: Fri Jan 06, 2017 11:28 am Post subject: |
Working on both my PC's but not on M8's 2 Win10 PC's
At the moment I've got no idea why it just produces a rotating wheel then dies. _________________ Satnav:
Car Average MPG :
Posted: Fri Jan 06, 2017 11:30 am Post subject: |
I am running W10 as well. The previous version works with no problems. |
Posted: Fri Jan 06, 2017 12:03 pm Post subject: |
We have some progress.
Something has occurred on Win10 that is preventing ClickOnce applications running from the icon. It seems it needs Administrator privileges now.
The application exe is sitting in
C:\Windows\Users\(your username)\AppData\Local\Apps\2.0\ (weird 8.3 folder name)\ (another weird 8.3 folder name)\ csvt...rter~
Clicking the exe in there works.
Investigating ...................... _________________ Satnav:
Car Average MPG :
M8TJT The Other Tired Old Man
![The Other Tired Old Man The Other Tired Old Man](modules/Forums/images/ranks/verifier.gif)
![](http://maft.co.uk/avatars/m8tjt.jpg)
Posted: Fri Jan 06, 2017 12:24 pm Post subject: |
Problem with the 'weirdly named' folders is that the one s for Direction Converter are in there as well. Be warned if you run that in conjunction with GPX converter |
Posted: Fri Jan 06, 2017 1:50 pm Post subject: |
Allan, do you have UAC turned on ? _________________ Satnav:
Car Average MPG :
Posted: Fri Jan 06, 2017 2:06 pm Post subject: |
No, I switched off UAC when I upgraded. |
Posted: Fri Jan 06, 2017 2:20 pm Post subject: |
Another 'hit' I found was that .NET 4.5.1 may be needed so I've upgraded to that and recompiled.
Latest in the beta link.
Allan, does yours also run OK when double clicking the exe from the link:
C:\Windows\Users\(your username)\AppData\Local\Apps\2.0\ (weird 8.3 folder name)\ (another weird 8.3 folder name)\ csvt...rter~ _________________ Satnav:
Car Average MPG :
Posted: Fri Jan 06, 2017 3:43 pm Post subject: |
I need to install the latest version and see what happens. I'll let you know as soon as I can. |
Posted: Fri Jan 06, 2017 4:31 pm Post subject: |
Thanks Allan
I've spent all day on the phone with M8TJT and we have concluded that something has occurred, more than likely on my PC that is interfering with the deployment on Win10 PC's.
All I can think of is that Wed or Thu, when I shut my PC down it came up with the 'Configuring Updates' message even though I hadn't updated anything.
The only other curious thing is that it's working on another Win7 PC.
At the moment I have no idea, but I'm still looking.
The issue is the link between the Desktop Icon and the exe because when the exe, in the location above is run manually, it works. _________________ Satnav:
Car Average MPG :
