Pocket GPS World :: View topic - Mercedes Comand Online ntg4.5 - Personal POI data support
Goto page Previous  1, 2, 3 ... 12, 13, 14, 15, 16, 17  Next
PostPosted: Fri Dec 23, 2016 3:23 pm    Post subject: Reply with quote
You obviously didn't read the thread as this was posted, amonst others on the previous page to your last post that says you must leave the SD card in the car.
wartklin wrote:
Ot might also be worth while emboldening the last para, as it seems that some people may not realise that you have to leave the SD in in the device.
Yes it is important that you create a folder nameley "PerosnalPOI"as this is the only folder you should have on the SD card and the gpx files are loaded into this folder.
I agree with Kremmen for you to have a go at getting the voices to work though. Very Happy That would be a good result. Shocked
ticitybo
PostPosted: Fri Dec 23, 2016 3:28 pm    Post subject: Reply with quote
Oh, that sounds a bit more complicated and I've got no idea what SOX.exe is or what it does :-)
Will do a search during the Christmas break to see if I can figure this one out.
PostPosted: Fri Dec 23, 2016 3:42 pm    Post subject: Reply with quote
SOX.exe is a small program that POILoader uses to convert .WAV files into something the Garmin can use.
There's loads of expertise here. If you are up for the challenge after the hol, then come back and I'm sure that Kremmen (the real expert) will hold your hand on how to do it.
PostPosted: Fri Dec 23, 2016 4:32 pm    Post subject: Reply with quote
All joking apart, getting the wav files to work with sox and into the gpi file is well worth the effort.
It's a one off file move into the POILoader folder once you have the sox.exe
It's the icing on the cake.
There are already loads of posts here with sox explanations including a few I've posted with pictures.
PostPosted: Fri Dec 23, 2016 7:22 pm    Post subject: Reply with quote
@ticitybo
Can you set up proximity distances, or is it set by the device?
@Kremmen
The problem with posts about SOX.EXE is that there is so much chaff to sort the wheat from, just a few pearls of wisdom scattered amongst the dross including confusion as to which folder it should go in.
PostPosted: Fri Dec 23, 2016 7:51 pm    Post subject: Reply with quote
My problem at the moment is that I'd like to include the existing graphic of the POILoader folder with the sox shown at the end, but, I'm away from the PC and trying to be clever on a phone is impossible.
Isn't there that Noddy guide somewhere ?
PostPosted: Fri Dec 23, 2016 8:23 pm    Post subject: Reply with quote
Yes, but it's not easy to find. I couldn't. I expect you wrote it K.
PostPosted: Sat Dec 24, 2016 5:58 am    Post subject: Reply with quote
I did, and you named it at the time Laughing
c180081c
PostPosted: Sat Mar 11, 2017 9:48 pm    Post subject: Reply with quote
My COMAND works with the files fine however when I turn the car off it forgets and I have to reload, any tips?
PostPosted: Sat Mar 11, 2017 10:28 pm    Post subject: Reply with quote
Sorry to butt in. Smile
Did you mean This?
Or this:
shinydoc
PostPosted: Mon Jun 12, 2017 6:34 pm    Post subject: W213 Command NTG5E Reply with quote
Hi All,
I have a new W213 E-Class with Command version NTG5E and cannot get any of these methods to work.
Some won't work as the options do not appear anyway.
Am I the only one with this problem, or has someone managed to get it to work on these variants?
I have really missed my PGPSW files, having a TomTom Go5000 too and there is no working solution for that either Sad
I guess manufacturers just want to corner the market and continually rip us off.
PostPosted: Mon Jun 12, 2017 9:00 pm    Post subject: Re: W213 Command NTG5E Reply with quote
That sounds about right
Si_23
PostPosted: Mon Jun 12, 2017 9:13 pm    Post subject: Reply with quote
ticitybo wrote:
Ah ha. I’m sorted
Didn’t realise that with the system that is on the car I don’t need to import the speed camera data base and this is where I’ve been going wrong.
I simply copy the .gpi files (UK and EU) to the POI folder on the Garmin Map Pilot Europe 2016 SD Card and the system automatically reads the information and displays the camera as and when I approach one, it even plays a “bong” alert.
I've come to the conclusion I'm downloading the wrong files (.GPX) instead of .gpi. What SatNav system did you select from the download option?
shinydoc
PostPosted: Mon Jun 12, 2017 9:32 pm    Post subject: Reply with quote
Si_23 wrote:
ticitybo wrote:
Ah ha. I’m sorted
This is what I downloaded
Mercedes Comand [ UK - Single file with all cameras | pMobiles: Yes | French: No | Swiss: No ]
(15.061 - 07 Jun 17)
Si_23
PostPosted: Mon Jun 12, 2017 10:41 pm    Post subject: Reply with quote
shinydoc wrote:
Si_23 wrote:
ticitybo wrote:
Ah ha. I’m sorted
That is what I've just downloaded but it does not contain any .gpi files only .gpx. How did you get them to change to .gpi files?
Page 13 of 17
