Pocket GPS World :: View topic - Kenwood/Garmin DNX5520BT update issue
Elman
PostPosted: Fri Dec 09, 2016 3:23 pm    Post subject: Kenwood/Garmin DNX5520BT update issue Reply with quote
I have been using the camera updates on this site for some years now. I only update around every 6 months or so due to have to burn a cd to load it: howver the last two times I used the update though it seems to load; as there are no errors. I get no POis show, no warnings nothing.
The only way I can get it to work is to reload an update from March 2015?
Any one else had this issue?. Also note now there's a separate voice option were as before it was just one file?
Any help would be appreciated, otherwise will have to ditch using this site, thanks in advance
Michael
cjay2412
PostPosted: Fri Dec 09, 2016 8:32 pm    Post subject: Reply with quote
on the back of the unit, there is a mini b USB socket this gives direct access to the Garmin files allowing you to update the speed camera files via poi loader voice alerts for speed camera can also be loaded this way. run web updater to update other Garmin files like voices etc to the latest version. I have routed the USB cable to the glove box for easy access when plugging in the laptop.
22.062 (12 Jun 24)
