Pocket GPS World :: View topic - Range Rover Sport 2015
merigadi
PostPosted: Mon Nov 28, 2016 1:01 am    Post subject: Range Rover Sport 2015 Reply with quote
Hi guys,
Newbie here. I have been through this site and other RR forums.
On here I understand i should be following the Freelander method and on the other RR Forums use the Jaguar method.
I'm just a bit confused which one is going to work? I have downloaded both files to do trial and error. Going to try in the morning.
Thanks all
Privateer
PostPosted: Mon Nov 28, 2016 10:58 am    Post subject: Reply with quote
H merigadi,
Welcome to the forum Thumbs Up
Yes it's probably trial and error. Don't forget that you can use the free downloads to experiment with before you subscribe.
When you get it working could you post a step-by-step guide for other Range Rover Sport owners?
Robert.
Garmin Camper 770 LMT-D
merigadi
PostPosted: Sun Dec 04, 2016 9:29 pm    Post subject: Guide for LandRover RangeRover Sport 2015 Reply with quote
How To install Speed Camera POI's to Land Rover Range Rover Sport 2015
Download the following
SatNav System: Other - GPX.
Camera Selections: UK - Consolidated by Type.
IMPORTANT:
The USB memory stick MUST be formatted as FAT 32 with default allocation size selected.
Some users are finding that they cannot install the database. If this happens to you then you may need to split the gpx file into two - please contact support or ask in the forums if you need help with this.
Note: Voice guidance has to be enabled for you to hear the audible alerts (but this can be turned on and off easily enough). This should work on all LR with factory installed Hard Drive Sat Nav.
1. Start the he Engine (Ignition may switch off otherwise while you are installing the GPX files). On a cold day I highly recommend heated seats.
2. Insert USB Stick containing the Speed Camera POI's (POI files must be in .GPX format (See Handbook) and in the root folder of the drive, not in sub-folders.
3. Do the following:
Touch the Nav Button
Touch Nav. Menu Button
Touch More Button
Touch Stored Locations
Touch My POI Button
Touch Add Button
Touch "USB Drive" Button
You should now see a list of the POI's on your USB Stick
3. Touch the type of POI you want to install (Do one at a time, it is much safer that way)
If you get an error message, try again. It worked for me.
4. When you have installed all the POI's you want to install go to Edit and touch the Edit Button. This should bring up all the POI's you have installed including any previous ones you have installed. Touch the Speed Camera File you want to Edit (Example, Gatso-Mobile-Pmobile-Red Light-Specs), this will bring up a Menu to allow you to change the sound and Switch the Sound and Show on Map On or Off. PS it is recommended that you Switch both Sound and Shown on the Map to On.
5. To change the sound go to the Icon shown on Left Hand Side of screen Touch the Sound Icon it will bring up a list of Installed Sounds touch the one you want for that particular Camera & DON'T FORGET to touch OK before leaving that Menu Screen otherwise it will default to all Off.
Repeat this for all the Speed Camera Files you want to Edit, touching OK after each Edit. Touch Return to Map after you have Edited all the Cameras you want and Remove your USB stick.
6. Take the Car for a Drive near to some cameras you know about and test to see if working OK.
Note:
The Cameras will only work when you are in Map View or the Sat-Nav is guiding you. Once you have gone to Map view you can then go to other screens and Speed Cameras will continue to warn you. You MUST do this every time you start the car, if you don't go to Map View then the camera alerts will not warn you. Switching the Ignition off cancels Camera Alerts as it also Cancels the Map, but not a Route. (As Standard). You can select which cameras you want to warn you, or just have them showing on Map with No Sound.
22.055 (29 May 24)
