Pocket GPS World :: View topic - Audi SQ5 2016
Audi SQ5 2016
Stobbies
PostPosted: Mon Nov 21, 2016 10:05 am    Post subject: Audi SQ5 2016 Reply with quote
Hi, can anyone tell me if there is a compatible download for the MMI SatNav system in a 2016 Audi SQ5. I can only see RNS-E (or is that the same system?).
Thanks.
PostPosted: Mon Nov 21, 2016 10:41 am    Post subject: Reply with quote
In the majority of cases we need to see some sample data lines from any existing camera downloads you may have on the unit or card.
Do check back in case someone else knows as it may be a known VAG format.
Axel905
PostPosted: Mon Nov 28, 2016 11:49 pm    Post subject: Reply with quote
Given that the q5 is vag I suspect it needs to have the data processed through the VW Germany formatter.
I have the VW discovery sat nav media system, which I believe is the same as the Audi, although I think Audi call it mmi.
Personally I have used csv format for the data and bitmap for the images. Then I go to the VW Germany site. I think if you type VW poi Sammung into google it will take you to page. It will have the VW rns510 showing as the conversion format, so change this to discover, and then load your files. Do a google search for VW poi discover upload and there is a guide with an English translation.
The VW process produces a zip file which you'll need to unzip to the root directory of an sd card. Then insert the sd card to the nav and update the pois.
It's a bit long winded, but definitely works on the very latest VW systems which use the same it architecture as Audi, skoka and Bentley. So should work for the q5.
Hope this helps.
