Donn Occasional Visitor
Posted: Thu Sep 30, 2004 2:14 pm Post subject: Having problems getting signal on my iPAQ from Fortuna BT |
Hi there guys,
I have a problem in that I have a Compaq iPAQ 3970 together with a Fortuna Clip-On BT receiver. I am using Tomtom3.
I've managed to install Tomtom3 successfully and it seems to work, however I havn't managed to get both PDA and GPS receiver to work together.
I have tried a lot of different settings, obtained from the fortuna documentation and this website. However none seems to work successfully.
I was wondering whether anyone out there has an answer to this problem.
If you do, then please feel free to post a reply on this matter.
Regards
Donn |
lbendlin Pocket GPS Staff
Posted: Thu Sep 30, 2004 2:45 pm Post subject: |
here's what you need to do
- softt reset
- remove TomTom GPS driver
- soft reset
- make sure the TomTom GPS driver is really removed. If not, try again.
- install TomTom GPS 2.07 (from our downloads page)
- in BT Manager, find the Fortuna and connect to its serial port
- Start > Settings >System > GPS - go to the GPS tab and select NMEA 38400 in the top dropdown and Bluetooth COM8 in the bottom dropdown
- check the checkbox
- go to the status tab and see if the black dots are running _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Thu Sep 30, 2004 3:54 pm Post subject: |
Thanks for the help matey, however after doing all of the above I still do not get any black dots in the status tab. Maybe ther's something I'm not doing.
Do I need to uninstall Tomtom3 Navigator first?
Regards
Donn |
Posted: Thu Sep 30, 2004 4:19 pm Post subject: |
No, the TTN is not of concern at that time.
Can you confirm that you REALLY have the TomTom GPS 2.07 installed? What does the version number say?
Have you tried a GPS utility like Crux_View? _________________ Lutz
Posted: Thu Sep 30, 2004 4:36 pm Post subject: |
Yes I definately have the right version installed, as it says v2.07. I have not tried crux view, so I will do that now.
Regards
Donn |
Posted: Thu Sep 30, 2004 5:23 pm Post subject: |
I've installed CRUX VIEW, However how the hell do you use it? There are no help files with it so I havn't a clue to be honest with you. Maybe someone on the forum knows more about this.
Regards
Donn |
Posted: Thu Sep 30, 2004 8:29 pm Post subject: |
select port COM7 and speed 38400, and then tap "open"... _________________ Lutz
Posted: Fri Oct 01, 2004 1:24 am Post subject: |
lbendlin wrote: | select port COM7 and speed 38400, and then tap "open"... |
Hi there,
Tried all of the above 2-3 times. All I get is a "READ ERROR!!RESET GPS?" Wonder if that makes sense to any of you guys on the forum?
Regards
Donn |
Posted: Fri Oct 01, 2004 1:40 am Post subject: |
it may not be COM 7 after all...My fault. It should have read COM8 on the 3970. _________________ Lutz
Posted: Fri Oct 01, 2004 2:29 am Post subject: |
lbendlin wrote: | it may not be COM 7 after all...My fault. It should have read COM8 on the 3970. |
Hi there,
I have tried that as well, and I get the same error as last time. I don't know what else to do.
Regards
Donn |
Posted: Fri Oct 01, 2004 2:56 am Post subject: |
what other ports are listed in the TomTom GPS utility? _________________ Lutz
Posted: Fri Oct 01, 2004 2:38 pm Post subject: |
lbendlin wrote: | what other ports are listed in the TomTom GPS utility? |
The other ports that are listed are as follows:
COM3,
IRDA,
COM5,
SERIAL CABLE ON BT,
SERIAL CABLE ON COM 1,
SERIAL ON USB,
BT SERIAL PORT COM8,
BT SERIAL PORT COM7.
Hope all of the above is of help to you.
Regards
Donn |
Posted: Fri Oct 01, 2004 3:27 pm Post subject: |
Looks normal, and COM8 should work. Do you have a chance to test other BT gear with the iPAQ? _________________ Lutz
Posted: Fri Oct 01, 2004 4:17 pm Post subject: |
lbendlin wrote: | Looks normal, and COM8 should work. Do you have a chance to test other BT gear with the iPAQ? |
Yes I agree it should work, but for some strange reason it doesn't. I can get the iPAQ to bond with the BT receiver and the blue led on the receiver seems to flash very quickly, which is a good sign. And so everything seems to be up and running till that point.
However nothing happens after that, in that there is no visable indication that anything is happening.
I do have other BT gear, namely a BT phone, which I have used sucessfully. I sent a contacts contact details via BT to my iPAQ and it worked on the first try. So I know it does work, now all I need to do is get the iPAQ and the BT receiver to work . Easier said that done I suppose.
Regards
Donn |
Posted: Sat Oct 02, 2004 12:11 am Post subject: |
Maybe the Fortuna can use a little hard reset? _________________ Lutz
