alimckali Occasional Visitor
Posted: Tue Oct 11, 2016 9:54 pm Post subject: Brand new TomTom VIA 135 compatible? |
Hi guys,
It says on the PGPSW list of compatible systems that "all VIA" tomtoms are compatible. Is the new VIA 135 compatible then? (by 'new' I mean you can still buy it new in Argos etc. with lifetime Tomtom maps)
I thought TomTom stopped producing compatible satnavs a few years ago....
Just want to check before buying a new one because otherwise I will get an older model like the VIA 125.
Many thanks,
Ali |
M8TJT The Other Tired Old Man
Posted: Tue Oct 11, 2016 11:24 pm Post subject: |
I believe that you can load user POIs onto your device, but there is no proximity alert for them. So they are about as useful as tits on a bull for third party speed camera alerts. But I may be wrong and a TT expert will be along in a bit to clarify.
EDIT. TT expert present and correct. Seems like I was wrong.
Anita Pocket GPS Moderator
Posted: Tue Oct 11, 2016 11:44 pm Post subject: |
I bought my VIA135 in April 2014, so not exactly new, but there are some still available online, so assuming your model is the same as mine you can install the camera database and set up proximity warnings using MyDrive Connect. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
Posted: Wed Oct 12, 2016 8:09 am Post subject: |
Are there any clues in the settings that might indicate whether the OP's device is compatible Anita? |
Posted: Wed Oct 12, 2016 9:40 am Post subject: |
He says he wants to know before buying it from Argos, M8, so probably won't be able to check first, although he could probably return it if he finds it doesn't meet his requirements.
Proximity alerts are set up via Settings | Manage POIs | Warn when near POI, but presumably this option would be present on all devices for setting up warnings for TomTom POIs.
I would be fairly certain any VIA135 currently available would be the same as mine. Surely even TT wouldn't reuse the model name quite so soon! _________________ Anita
UK map 1130.12368
marksfish Pocket GPS Verifier
Joined: Jun 25, 2005 Posts: 802 Location: Sandy, Bedfordshire
Posted: Wed Oct 12, 2016 8:49 pm Post subject: |
A via 135 is the last generation of units which accepts POIs and some are still available. I had one until replacing with a Garmin, I then had to convert all my own user generated POIs to csv format!!
Mark _________________ Garmin Drivesmart 51 LMT-D Europe |
Posted: Wed Oct 12, 2016 11:47 pm Post subject: |
Thanks guys, sounds promising I'll give it a shot and like you say can always return it. Argos are pretty good with returns.
Anita how are you finding the 135 generally? It's got a bunch of really bad reviews on amazon. |
Kremmen Pocket GPS Verifier
Posted: Thu Oct 13, 2016 4:40 am Post subject: |
The problem with reviews is that you have to sort the old from new.
The vast majority of reviews for most products tend to be from people who have only had the item for days or weeks and can be misleading.
I try to home in on the ones, if there are any, that say they have had the item for 6 months or so. _________________ DashCam:
Viofo A119 V3 |
pocketjotter Occasional Visitor
Posted: Mon Dec 05, 2016 2:56 pm Post subject: |
alimckali wrote: | Thanks guys, sounds promising I'll give it a shot and like you say can always return it. Argos are pretty good with returns.
Hi Alimckali
Did you purchase the current Via 135 model in the end and if so have you loaded the speed camera database. I'm considering it myself, but the photos look like the later type screen layout and I suspect has the same problems as the start range etc.
thanks.
pocketjotter  |
Posted: Mon Dec 19, 2016 5:34 pm Post subject: |
To answer my own question.
I purchased a TT Via 135 from Argos in Dec 2016 and I have been able to download the camera database and set the Proximity alerts.
In fact the 135 is very similar to the one XL. I just have to get used to the different way of loading the database using Tom Tom drive.
I'm not keen on the fixed mount though.
pocketjotter  |
Posted: Mon Dec 19, 2016 6:04 pm Post subject: |
I'm guessing but presumably this is old stock if it allows the .ov2 files?
If so then whilst you have the database does it have live traffic? _________________ DashCam:
Viofo A119 V3 |
Posted: Mon Dec 19, 2016 6:33 pm Post subject: |
Yes, it's old stock and the last TT model that can use the camera database in a useful manner.
No, it doesn't have live traffic. _________________ Anita
UK map 1130.12368
Posted: Mon Dec 19, 2016 7:39 pm Post subject: |
Viofo A119 V3 |
