M8TJT The Other Tired Old Man
Posted: Sat Aug 20, 2016 7:06 pm Post subject: |
But why on earth did you have to quote three previous posts taking up all that space instead of just the 6 or 7 lines that were all that was required? Use the 'Post reply' button at the bottom unless you have to quote to get your post in context.  |
wartklin Occasional Visitor
Posted: Sat Aug 20, 2016 8:27 pm Post subject: |
Point taken, but it doesn't have to be so terse! |
Posted: Sun Aug 21, 2016 8:29 am Post subject: |
Please accept my apologies for my terseness.
I must use the word please more often  |
Posted: Sun Aug 21, 2016 8:59 am Post subject: |
Thank you accepted in the manner it was given.
Keep up the good work.
Regards |
ellick Occasional Visitor
Posted: Sun Aug 21, 2016 12:34 pm Post subject: Re: Comand ntg5 |
Hi ellick it's me again.
I have had success.
Thanks it has been a good result all round.
Cheers[/quote]
Hi Wartklin,
I am glad it worked for you too. Credit must go to 'BBJtech', I just happened across his post.
It is a much better way for ntg5.1.
Best wishes,
Ellick. |
Si_23 Occasional Visitor
Posted: Sun Sep 18, 2016 4:57 pm Post subject: NTG5E |
I have a 2016 Merc GLC with SD Card Garmin MAP Pilot Europe 2015/2016 V1.2 Map 5.0. Have tried all the suggested instruction after downloading the speed camera files and still the Sat Nav does not display speed cameras.
I've come to the conclusion that these files do not work with the latest version of the Merc Garmin Map Pilot.
If this is the case can I get my £19:99 refunded
Si. |
Posted: Wed Sep 21, 2016 2:11 pm Post subject: Re: NTG5E |
Si_23 wrote: | I have a 2016 Merc GLC with SD Card Garmin MAP Pilot Europe 2015/2016 V1.2 Map 5.0. Have tried all the suggested instruction after downloading the speed camera files and still the Sat Nav does not display speed cameras.
Si. |
Hello,
I had lots of problems trying to put the speed camera data base on ntg5 Mercedes Comand.
I tried this: -
'Firstly make sure you create a folder called - PersonalPOI - (without the dashes) in the route of the SD Card. The spelling and capitals are important
Then copy the 2 extracted .gpx files to the PersonalPOI folder
After that, all I do is insert the SD card into the car slot and leave it. After a couple of minutes if I drive off the database has automatically loaded and I receive camera alerts as expected'
You must only transfer the 2 extracted gpx files to the folder on the SD card.
When the cameras show on the navigation map choose options and make sure 'show on map' and 'audible alert' is ticked.
Good luck.
Ellick |
Posted: Wed Sep 21, 2016 10:55 pm Post subject: Re: NTG5E |
ellick wrote: | Si_23 wrote: | I have a 2016 Merc GLC with SD Card Garmin MAP Pilot Europe 2015/2016 V1.2 Map 5.0. Have tried all the suggested instruction after downloading the speed camera files and still the Sat Nav does not display speed cameras.
Si. |
Hello,
I tried this: -
Good luck.
Ellick |
Thanks Ellick, I did see your previous post and had tried to the letter exactly what you suggested but I get no cameras appearing on the map.
I'm wondering if the fact I'm running a newer version of the Merc Map Pilot NTG5E is the problem and it is not compatible with gpx files that have been downloaded.
Rgds & Thanks.
Si |
DingleRoad Occasional Visitor
Posted: Tue Nov 08, 2016 1:38 pm Post subject: |
I've just got a new Merc. GLC with Command on Line , the map version says ,
2016 (V8.0) EUROPE
Satellite view of Earth: NASA Visible Earth
Downloaded the Speed Camera POIs and they work a treat
Advanced warning, audible and visible alert which I wasn't expecting....thanks PGPSW !!! |
the_big_1 Occasional Visitor
Posted: Sun Dec 11, 2016 5:55 pm Post subject: |
I have just purchased a 2015 W205 AMG C63. I downloaded the files under the Mercedes link on the download page. I formated my SD card to ensure its clean.
I created a folder PersonelPOI and then extracted the zipped files in to the folder.
I put the SD card in the SD slot in the arm rest then switched on the command system.
I select Personal POI in the menu and all I get is a message "Place SD card in slot with personel POI's" the car doesnt seem to see the card, any idea why? My pc cn see them no problem! |
Kremmen Pocket GPS Verifier
Posted: Sun Dec 11, 2016 6:44 pm Post subject: |
As a generic reply, as I haven't got a Merc, check the format of the card.
Usually these systems like plain old FAT and dislike NTFS _________________ DashCam:
Viofo A119 V3 |
ticitybo Occasional Visitor
Posted: Mon Dec 19, 2016 10:13 pm Post subject: |
Having a bit of problem installing the speed camera data base onto the Garmin Map Pilot SD Card Europe 2016 and wondered if anyone could offer any advice as to what I’m doing wrong or is it an issue with the Command System on-board the car? Details as follows;
Car – 2016 Mercedes AMG SLC43, 3 weeks old
When I view the system the Command System is listed as NTG5Star1, software Version 38.18
SD Card Garmin Map Pilot Europe 2016, V6 Map 6.0
I’ve tried loading the speed camera database as a .gpi file using the naming convention of Speedcams_UK_Camera.gpi and placed it in the POI folder on the SD card.
That didn’t work, so I created a folder called PersonalPOI within the main folder on the SD card and loaded speed camera data base in there.
That didn’t work either, so I created a folder called PersonalPOI as a stand alone folder on the SD card and loaded the camera data base in there.
That didn’t work either.
The main issue seems to be that when I enter the Navi menu there isn’t an option to import or copy any personal POI’s or is the system supposed to just pull the POI’s automatically into the sat nav?
The other method that I’ve tried is loading the speed camera database using the Garmin POI Loader and letting it place the POI camera file directly into the POI folder on the original Mercedes supplied SD card and that didn’t work either.
Am I doing something wrong or perhaps it’s due to the particular Command system that is installed in the car?
Hope someone can help. |
crypto56 Occasional Visitor
Posted: Fri Dec 23, 2016 1:06 pm Post subject: Still no luck |
I have a W213 E-Class with Widescreen cockpit and Comand online , So NTG5.5 and I have tried everything stated on these and i cant get it to work.
Formatted the card Fat32 - Created the folder - copied the 2 files - left it inside the mem slot in the car and nothing is happening
Can anyone help please |
Posted: Fri Dec 23, 2016 1:55 pm Post subject: |
Ah ha. I’m sorted
Didn’t realise that with the system that is on the car I don’t need to import the speed camera data base and this is where I’ve been going wrong.
I simply copy the .gpi files (UK and EU) to the POI folder on the Garmin Map Pilot Europe 2016 SD Card and the system automatically reads the information and displays the camera as and when I approach one, it even plays a “bong” alert. |
Posted: Fri Dec 23, 2016 3:18 pm Post subject: |
Good
Your next mission, should you choose to accept it, is to use POIloader with the appropriate .wav files and SOX.exe in place.
The object of the exercise is to see if you can replace the global fairly meaningless bong to a nice verbal warning like "Fixed Camera Ahead, 50 miles per hour" like we do on the Garmin PND's in our .gpi files.
This message will self destr........... _________________ DashCam:
Viofo A119 V3 |
