M8TJT The Other Tired Old Man
![The Other Tired Old Man The Other Tired Old Man](modules/Forums/images/ranks/verifier.gif)
![](http://maft.co.uk/avatars/m8tjt.jpg)
Posted: Thu May 19, 2016 2:11 pm Post subject: |
Kremmen wrote: | This is just separated by speed as I didn't consider trying to separate it out by camera type as well. | Don't make a rod for your own back K. Surely a single overspeed % setting is enough for all speeds and cams. Set to 12.5% gives a fair approximation to 10%+2MPH across the speed range. |
Kremmen Pocket GPS Verifier
![Pocket GPS Verifier Pocket GPS Verifier](modules/Forums/images/ranks/verifier.gif)
![](modules/Forums/images/avatars/4810985884fb0a2b6dedb3.gif)
Posted: Thu May 19, 2016 2:52 pm Post subject: |
It's done by speed so you can do 10% + 2 or just raise each one by 1 or 2 mph.
What I've done is quite basic but if it works I can expand it quite easily. _________________ Satnav:
Car Average MPG :
Posted: Fri May 20, 2016 7:16 am Post subject: |
V 45
Small cosmetic bug fixes and TOC added into Word help document.
Same link as V44 (beta) _________________ Satnav:
Car Average MPG :
Allan_whoops Frequent Visitor
Posted: Fri May 20, 2016 8:09 am Post subject: |
Thanks for all your efforts on this. It makes life so much easier!
Allan |
Posted: Fri May 20, 2016 8:30 am Post subject: |
It's evolving
The source code is available to anyone on request. No secrets here. _________________ Satnav:
Car Average MPG :
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Fri May 20, 2016 8:52 am Post subject: |
Only source code I need is one that let's me get a bottle of HP cheaply ![Wink](modules/Forums/images/smiles/icon_wink.gif) _________________ Where there's a will ... there's a way. |
walkabout Occasional Visitor
Posted: Sun May 22, 2016 7:20 pm Post subject: |
I may be doing something wrong, but the help file says the photo links are broken?
Is this a known issue?
Mark |
Posted: Sun May 22, 2016 7:31 pm Post subject: |
I think Im getting to grips with this program.
Its great and after using ASH's program for years it a big improvement.
A question, I am dragging the downloaded PGPSW file into my working directory, do I have to delete that file before dragging the new one in?
Or does the program see the new one automatically?
Mark |
Posted: Sun May 22, 2016 7:37 pm Post subject: |
It will overwrite the first one if you keep the name the same. You then select it as before when you click on Unzip PGPSW Camera Files _________________ Where there's a will ... there's a way. |
Posted: Mon May 23, 2016 4:33 am Post subject: |
That's what I do or you can't see the wood for the trees. _________________ Satnav:
Car Average MPG :
Nemesis1 Regular Visitor
Posted: Wed May 25, 2016 3:54 pm Post subject: |
I'm trying to decide whether to get a small Garmin (what's the smallest one they do?) or the RAC dash cam. I'm done trying to figure out the complexities of the Merc system, no matter what I try it's just not consistent enough.
Can you answer a couple of questions for me please Kremmen (or anybody).
Can I get a 100% guaranteed icon on the display for all POI alert based or not.
Can I get a guaranteed alert for every camera irrespective of my speed or what Garmin think I should be alerted to.
On the system in my old Audi and my Tom Tom before that, I had icons that populated the map so I could see them all over the display, and an alert as I approached one on my route. If I can replicate this on a Garmin, I think I'm leaning that way with the added incentive of the digital traffic.
What I was thinking to do is load 2 sets of the database, one just as a standard POI file with no alerts to populate the entire map with icons, and one with no icon files solely to generate the alerts at distances and wording of my choosing via Kremmens app.
Thanks.
Posted: Wed May 25, 2016 4:06 pm Post subject: |
Nemesis1 wrote: | Can I get a 100% guaranteed icon on the display for all POI alert based or not. | Only when you are travelling, they can be a bit hit and miss whilst in couch mode. Quote: | Can I get a guaranteed alert for every camera irrespective of my speed or what Garmin think I should be alerted to. | As long as you setup Kremmens gizmo correctly.
BTW, it's unlikely that anyone will give you a 100% guarantee. Even Detol only claim it kills 99.9% of all known household germs (But that's only to cover themselves in case someone finds one). |
Posted: Wed May 25, 2016 4:28 pm Post subject: |
Thanks mate.
If the icons are present as I'm moving that's fine, I don't intend scanning the map while stationary to look for them. Although Garmins own literature suggests that any non alert POI can be set as a destination, so I guess if I where to scroll around these would pop up? That's why I was thinking of loading the database twice, once with all alert trigger words and speed info removed.
Unfortunately I can't think of any way to test this without buying a Garmin :-/
I already have a dash cam, and the RAC one is attractive as it would just replace that without adding extra kit all over my screen/dash. But I have reservations over the update frequency and how configurable it is alert wise.
One more quick question. On my old TT I could 'add' POI on the device as I was moving with 2 clicks on the screen to save the lat and long, and then send that info (if it was a camera) to you guys. Can I do the same on a Garmin?
Thanks. |
Posted: Wed May 25, 2016 5:28 pm Post subject: |
You can save current location by tapping the vehicle icon then Save. _________________ Where there's a will ... there's a way. |
Posted: Wed May 25, 2016 5:32 pm Post subject: |
I know you only really need a cheapo Garmin for the cameras but think about the traffic.
My Honda only has TMC RDS traffic which is crippled when compared to Garmins digital traffic.
I did a journey today (Eastbourne to Heathrow) via the A roads and Motorways and Garmin was considerably more accurate on the M25 which was a bit sticky in places this morning. As the traffic conditions changed the Garmin changed with them but the TMC display showed traffic for ages after it had cleared. _________________ Satnav:
Car Average MPG :
