Pocket GPS World :: View topic - Newbie - Screen shows GPS Disabled - What do I do?
DOODBRIE
PostPosted: Wed Sep 29, 2004 3:27 pm    Post subject: Newbie - Screen shows GPS Disabled - What do I do? Reply with quote
Dell Axim Tom Tom 3
This is the first time I have tried to use the Sat nav but not with much luck so far. Set it up in my Car, planned a route but the Screen shows GPS Disabled, looked in the menu for a Sat signal but it appears not to be able to pick one up. I also have a Pharos iGPS-360 cf Card, the one you plug in to the top and apparently you can use it walking about but still no Signal?
How do I check to make sure everthing is set up properly so I can use it?
(be gentle with me)
Any and all advice would be really appreciated.
Cheers guys
Ian Confused
PostPosted: Wed Sep 29, 2004 5:51 pm    Post subject: Reply with quote
- Soft reset your PDA
- tap Start > Settings > System > GPS
- go to the GPS tab and select your CF card from the bottom list. Select NMEA 38400 in the top list
- enable the GPS by tapping the checkbox
- go back to the Status tab and see if the black dots are running
let us know how it goes
Howarduk
PostPosted: Fri Oct 01, 2004 1:44 am    Post subject: Reply with quote
If its the first time you have tried to get the SatNav working it does take about 30-45 minutes for a first fix, after that it will work within about 15-20 seconds.
Howard
22.105 (30 Oct 24)
