M8TJT The Other Tired Old Man
Posted: Sun May 01, 2016 9:53 am Post subject: |
@ Spikeyman. Please use the post reply button at the bottom of the thread instead of the quote button. It is not usually necessary to quote the message immediately above yours when you are replying to it. It clutters up the thread.
Have you got any left over files in your working folder with numbers in their filenames?
Clear out your working folder, make sure that it hasn't got any sub folders and try again.
Ah, I see, you already did that and it worked. (Cross posted) Good result then. Quote: | I have done everything correctly, | So you hadn't then.  |
Kremmen Pocket GPS Verifier
Posted: Sun May 01, 2016 3:13 pm Post subject: |
The latest version of the Converter has been thoroughly tested by 2 people as well as my unit testing so I'm quite confident there are no inherent bugs now.
In this instance where the message is warning of a numeric filename then - there is a numeric filename that needs dealing with. _________________ DashCam:
Viofo A119 V3 |
Spikeyman Occasional Visitor
Posted: Tue May 03, 2016 1:25 pm Post subject: |
Many thanks to all the people who took the time to explain the procedures to me, your help was invaluable.  |
Posted: Tue May 03, 2016 3:13 pm Post subject: |
I assume that you are now fully sorted then? |
Posted: Thu May 05, 2016 2:03 pm Post subject: |
Yes thank you very much for all your assistance.
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4462 Location: West Sussex
Posted: Thu May 05, 2016 2:10 pm Post subject: |
Would be good to know what the issue was as it could help others  _________________ Where there's a will ... there's a way. |
Posted: Thu May 05, 2016 2:14 pm Post subject: |
Double post so deleted  _________________ Where there's a will ... there's a way. |
