M8TJT The Other Tired Old Man
Posted: Sun Apr 17, 2016 8:16 am Post subject: |
Kremmen wrote: | 1) Download the new map to a location of your choice.
2) Once downloaded and verified then another button to build and load the map files. | That makes far too much sense K. Esp your point 1). |
MimiLabonq Occasional Visitor
Posted: Sun Apr 17, 2016 8:50 am Post subject: |
M8TJT wrote: | Kremmen wrote: | 1) Download the new map to a location of your choice.
Stobie, it's seems curious (to me at least) that my update stuck at 1 hour 48 min and yours at 1 hour 31 min. Hopefully, one of the experts on here can explain why?
In future, I'm going to wait a couple of weeks or so before updating like I usually do. I can do without the stress! |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Sun Apr 17, 2016 8:54 am Post subject: |
Well there are far too many reasons why a map update may appear to be or is actually stuck to be able to explain every one. The vast majority go without a hitch.
However it's one reason why many folks decide to use a clone device to download the update so that if there ever is an issue the satnav isn't affected. _________________ Where there's a will ... there's a way. |
Posted: Sun Apr 17, 2016 9:11 am Post subject: |
Thank you, sussamb. I've had seven updates go without a hitch previously.
May I ask what you mean by a clone device? |
Posted: Sun Apr 17, 2016 9:30 am Post subject: |
To create a clone you copy the Garmin folder from your device to a SD card or USB stick. Express will see that as your device, since the Garmin folder contains the file GarminDevice.xml which is the file that contains the details about your device.
Express will install all the updates then to your card/stick. Having done that successfully you then manually copy the files to your device. _________________ Where there's a will ... there's a way. |
Posted: Sun Apr 17, 2016 9:43 am Post subject: |
Ah, I see. Thank you! |
Posted: Sun Apr 17, 2016 12:17 pm Post subject: |
I'll second that thanks suss. Now to get a card and get on with it. |
Kremmen Pocket GPS Verifier
Posted: Sun Apr 17, 2016 3:05 pm Post subject: |
I must be in the minority that has had more failures than clean map updates. Fortunately a second run always seems to either carry on from where it failed or has a second try using the already downloaded maps. _________________ Satnav:
Car Average MPG :
locksmith Lifetime Member
Posted: Fri Apr 22, 2016 10:07 am Post subject: |
I had the same thing a week or so ago with my nuvicam. It had previously updated ok out of the box but hung on updating the 2017 map.
I tried again today and bingo it took about 15 minutes!!
Just checked that the 2017 was indeed loaded (yes) but there is an additional "map" Europe DEM. What is that? |
Posted: Fri Apr 22, 2016 10:24 am Post subject: |
Typing 'Europe DEM' into Google would have saved you quite a lot of typing |
Posted: Fri Apr 22, 2016 10:48 am Post subject: |
Thanks.
Strangely I get a skimlinks page cicking that link? |
Posted: Fri Apr 22, 2016 11:03 am Post subject: |
Not sure what that is?
Just Google What is a DEM basemap if that link isn't working for you. _________________ Where there's a will ... there's a way. |
Posted: Fri Apr 22, 2016 11:47 am Post subject: |
Link works just fine and dandy for me.
Get rid of skimlinks in your browser. |
Posted: Fri Apr 22, 2016 11:49 am Post subject: |
Its in my browser?
No idea what that means |
