I'm having the same problem here with the 32 files limit.
Its the first time I've encountered this and I've started a new thread because I think the PGPSW data set might need to be amended.
On the topic of this thread, I've just discovered Kremmen's converter and I'm having a first go at using it. It looks perfect as I have always manually set up my warnings in POILoader. It's tedious and I get mixed results.
I notice that Kremmen's converter does not have categories for the TBA CSVs. I'm not sure why these have been created and have suggested that they are perhaps merged with VARs since setting up warnings would be the same (i.e. we don't know the speed so speed based warning are out).
Posted: Fri Apr 01, 2016 2:38 pm Post subject:
The 32 files is actually 32 folders. Don't get confused.
We have been testing the new Direction Converter in conjunction with the CSV converter and all is fine even though the Direction Converter produces 120+ files.
What you need to investigate is the folder structure where you are asking POILoader to look at.
TBA = To Be Approved. These are cameras in each section that have usually only been reported once and are waiting for a second report or verification. Totally different to the var variable speed cameras. _________________ Satnav:
Car Average MPG :
Posted: Fri Apr 01, 2016 3:24 pm Post subject:
stringman wrote:
I them converted them with the prog, and uploaded the poi with POILoader.
this flagged up a warning about only having 32 items in a subfolder!!
See answer to stewartb above. You have multiple sub folders that POI loader doesn't like. Don't ignore it, fix it, else POI Loader just won't load them.
Page 9 of 9
