Pocket GPS World :: View topic - Audio files and sox.exe
Goto page Previous  1, 2, 3, 4, 5  Next
PostPosted: Thu Mar 17, 2016 6:25 am    Post subject: Reply with quote
Still haven't looked.
All depends on the verifier file contents. If they are a single file then easy peasy but but if they are separated into Gatso, Mobile, etc then a bit more work.
The POIloader ploy could be to have a working directory sub folder because POI would suck then into the same GPI. Or alternatively perform a second POI run on a second directory.
On my list.
PostPosted: Thu Mar 17, 2016 10:33 am    Post subject: Reply with quote
Reposted in kremmens verifiers thread
SILVERFOXE
PostPosted: Mon Mar 21, 2016 8:37 pm    Post subject: Reply with quote
Hi di ho it's me again looks like both of you were both right about MPH & KLMS reloaded speed cams & made sure MPH ws selected & all seems well , have had Garmins since 350 so have loaded sp/cams many many times & never made that mistake ,allways a first time a , any thanks for your help .
While I'm here can any one tell me how to stop Garmins red & grey speed banners appearing . I have ticked custom POI'S but they still keep appearing & they take up so much screen space .
Regards SILVERFOXE
PostPosted: Mon Mar 21, 2016 10:07 pm    Post subject: Reply with quote
Do you mean you're still getting Garmin warnings? If so delete the Garmin files from the POI folder.
SILVERFOXE
PostPosted: Wed Mar 23, 2016 5:27 pm    Post subject: Reply with quote
cannot see any thing Garmin in POI folder only my own stuff ,
PostPosted: Wed Mar 23, 2016 5:37 pm    Post subject: Reply with quote
In that case it must be the PGPSW warnings, they too produce a banner at the top of the screen similar to the Garmin ones.
PostPosted: Wed Mar 23, 2016 7:09 pm    Post subject: Reply with quote
The grey banner will be the PGPSW cameras and the red banner is the Cyclops cameras.
POILoader does not create a red banner.
Back to plan A searching for the Cyclops gpi file.
PostPosted: Wed Mar 23, 2016 7:25 pm    Post subject: Reply with quote
Given what K says search your nuvi and any card for any stray .gpi files, since your nuvi will hoover up a gpi file from anywhere, not just from the POI folder.
SILVERFOXE
PostPosted: Sat Mar 26, 2016 5:50 pm    Post subject: Reply with quote
Hi I cannot find a Cyclops folder anywhere having opened every thing that I can & the banner I'm referring to appears more or less in the middle of the screen and is red when warning is of over limit but go to grey when under limit , but why are they appearing when I have selected 3rd party POI's & I have never used Cyclops .
Regards SILVERFOXE
PostPosted: Sun Mar 27, 2016 1:19 pm    Post subject: Reply with quote
What device do you have? None of the recent nuvis do that. Can you post a screen shot of what you're seeing?
PostPosted: Sun Mar 27, 2016 2:22 pm    Post subject: Reply with quote
When is a banner not a banner ?
We definately need a screenshot.
dales
PostPosted: Mon Mar 28, 2016 5:45 pm    Post subject: Reply with quote
Here's something to check.
When sussamb said this "Do you mean you're still getting Garmin warnings? If so delete the Garmin files from the POI folder" he means for you to plug the device into your computer and to look in the device's internal storage.
In there, you should find a file called POI, containing files with names like UKIrelandCyclopsSample.gpi. The devices come preloaded with these, and they need deleting if you've got PGPSW warnings.
(Earlier on, you said this "cannot see any thing Garmin in POI folder only my own stuff" which sounds like you're searching your PC instead of the device's own memory).
Dales.
SILVERFOXE
PostPosted: Thu Apr 07, 2016 9:37 pm    Post subject: Reply with quote
[quote="Kremmen"]When is a banner not a banner ?
We definately need a screenshot.[/quote
Hi there folks ,have been away for a few days , have got screen shots as requested but cannot seem to find a way of posting them on here ?
Hi Dales When sussamb said this "Do you mean you're still getting Garmin warnings? If so delete the Garmin files from the POI folder" he means for you to plug the device into your computer and to look in the device's internal storage.
I have done all of this
PostPosted: Fri Apr 08, 2016 4:52 am    Post subject: Reply with quote
From re reading your posts I'm thinking you are referring to the Garmin's own overspeed warning that will turn the prevailing speed limit icon red and will produce a bong if you stray over the limit, and have the bong feature set.
If so then this is nothing to do with speed cameras/poi's that produce a banner at the very top of the screen.
PostPosted: Fri Apr 08, 2016 9:11 am    Post subject: Reply with quote
So how do you turn them off K. That would prove it one way or t'other.
On mine, it is Settings icon ~ Map & Vehicle ~ Audible Speed Alerts. Or is that just for the Audio?
Page 4 of 5
