Pocket GPS World :: View topic - Bugs list
Bugs list
Goto page 1, 2, 3, 4  Next
Venompeter
PostPosted: Tue Sep 28, 2004 11:20 pm    Post subject: Bugs list Reply with quote
One for a possible bugs list in this forum (not to put people off, but simply to collect together the known problems)
The "welcome to Copilot" sound doesnt respect the phone profiles, so you have to cover the speaker up with your finger if you are going to use it when quiet is required.
Peter
kartracer
PostPosted: Wed Sep 29, 2004 12:17 am    Post subject: Reply with quote
That's not really a bug, but if you want to you could delete the file CPWelcome.wav in the \Windows folder on your Pocket PC, or replace it with something quieter/shorter. That will shut it up. Laughing
Kam
PostPosted: Wed Sep 29, 2004 7:46 am    Post subject: Reply with quote
I think CoPilot (and TomTom) do force you into Outdoor profile as the application is running.
Venompeter
PostPosted: Wed Sep 29, 2004 12:59 pm    Post subject: Reply with quote
Thanks for the suggestion, I will try that.
njsb
PostPosted: Wed Sep 29, 2004 10:53 pm    Post subject: Reply with quote
I did change the settings through options to display 'Speed' rather than 'Destination' above the rotating next turn section. This didn't work nothing above rotating instructions, but has created more screen space for the map.
Would be interested in someone else trying to get Speed displayed.
njsb
Orange SanFransisco Smart phone
CoPilot 8 for Smartphone
stuartm
PostPosted: Thu Sep 30, 2004 10:45 am    Post subject: Reply with quote
Works for me:
Options, Safety View, Custom Display - Speed
stuartm
PostPosted: Thu Sep 30, 2004 10:47 am    Post subject: Reply with quote
Menu, 9 (Exit)
Brings up the dialling screen.
stuartm
PostPosted: Thu Sep 30, 2004 2:21 pm    Post subject: Reply with quote
Has anyone managed to get 'Avoid Road' to work?
Venompeter
PostPosted: Fri Oct 01, 2004 10:53 pm    Post subject: Reply with quote
re: the suggestion for stopping the "welcome" noise, that seems to be aimed at Pocket PCs, I couldnt find an equivalent on the Smartphone.
Peter
fozzie63
PostPosted: Sat Oct 02, 2004 6:26 pm    Post subject: Reply with quote
Just installed and am very impressed so far. Bugs/probs I've noticed using with my C500:
1. CoPilot does not keep the phones backlight on.
2. CoPilot does not override the Homescreen timeout, causing you to be dumped back to the homescreen after each timeou period.
3. Voice .wavs have been installed on the phone, despite Storage Card being selected.
4. I've been unable to add a Stop using 'contacts'. If I try, I get "No matches found for that address. Please check your entry". I have checked my contacts and all the address fields have been correctly populated. It's the same for several different contacts too.
Would appreciate any comments to confirm that it's not just me ;)
PostPosted: Sat Oct 02, 2004 8:21 pm    Post subject: Reply with quote
I don't believe this is a bug, it's more to save on battery power.
Unsure if this can be turned on/off by an app, but I'll check.
Common problem with PPC version also!
It's possible that some of the addresses aren't formulated correctly. Try entering these addresses manually in CoPilot and see if it finds it. I suspect it won't, and that's why it's having a problem.
fozzie63
PostPosted: Sun Oct 03, 2004 4:48 pm    Post subject: Reply with quote
Thanks for the quick reply Dave.
Understood. At least a voice announcement causes the backlight to come back on. However, I think there should be an option in CoPilot to 'Keep backlight on'.
Thanks.
Any idea if they're going to fix this one? Any reg edits to temporarily fix? I couldn't see any entries in the registry.
Hmmm, I've had done a little more experimentation but not getting too far. e.g. I have an address that has all fields correctly filled out but errors as above. If I try and enter number, street & postcode in CoPilot I also get the same error. If however, I enter number, street & town, then it matches ok?! I've checked the full address and postcode on the Royal Mail site and all is correct. Any ideas?
TIA.
PostPosted: Sun Oct 03, 2004 5:37 pm    Post subject: Reply with quote
WAV files installing to main memory is one of Lutz's pet peeves, and he does keep drumming it into ALK, so hopefully this will change.
TIA.
Don't enter all the information, try minimal information like town and street name. It's possible that the NAVTEQ maps don't have the information on house numbers for the streets you are trying and that may be causing a problem.
fozzie63
PostPosted: Sun Oct 03, 2004 6:13 pm    Post subject: Reply with quote
That's the weird thing. It's ok with number, street and town but not with postcode instead of town!?
PostPosted: Mon Oct 04, 2004 7:40 am    Post subject: Reply with quote
It's quite possible that with postcode it doesn't have the link back and that's causing confusion and not letting you search.
5 digit Postcode will take you down town level, sometimes sub-town level, so it may have a street it thinks is in sub town A when it's really in sub town B and that's causing postcodes not to work.
TBH, Contact integration is something that hasn't worked properly in all applications, because it does require 100% accuracy. Most companies tend to have a house name not number and this won't get picked up and will fail with most address lookup facilities, so contact integration so you'll probably find that most application will only work around 40% of the time when doing contact integration lookups. I avoid doing this in all applications and do manual searches.
Page 1 of 4
22.094 (25 Sep 24)
