sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Tue Mar 01, 2016 11:18 pm Post subject: |
Are you sure there are no other .gpi files anywhere on your device or sd card (if installed)?
If you are then I guess the next step is a master reset. _________________ Where there's a will ... there's a way. |
dales Frequent Visitor
Joined: May 04, 2008 Posts: 752 Location: Knaresborough, North Yorkshire.
Posted: Wed Mar 02, 2016 12:11 am Post subject: |
I agree.
Based on your answers, if there are no other gpi files on your device or SD card, and if there are no @ signs in any of your gpx files (check especially the ones for which you received overspeed warnings (mobile_Seventy.gpx or whatever)) then it seems that your device is not behaving properly. A master reset is well worth a try, but remember to reset your Single Tone and Custom Poi settings afterwards, and backup your favourites etc. beforehand.
Dales. _________________ nuvi 2599LMT-D, oregon 700, basecamp, memory-map. |
Kremmen Pocket GPS Verifier
![](modules/Forums/images/avatars/4810985884fb0a2b6dedb3.gif)
Posted: Wed Mar 02, 2016 5:57 am Post subject: |
I've just spotted the issue looking back at your screendump.......
You are not using the Converter to unzip the PGPSW files.
Therefore you have ~Gatso_50~ instead of ~Gatso_fifty~.
Having a number in the filename forces the unit to override any other setting.
Use the Converter to unzip the camera file and copy the audio and picture files from the installation folder as they already have the prefix removed.
0/10 for observation by me ![Rolling Eyes](modules/Forums/images/smiles/icon_rolleyes.gif) _________________ Satnav:
Car Average MPG :
ashley750 Occasional Visitor
Posted: Wed Mar 02, 2016 8:14 am Post subject: |
Kremmen,
Thanks. I'll retry tonight, using the converter to unzip the files :-) |
M8TJT The Other Tired Old Man
![The Other Tired Old Man The Other Tired Old Man](modules/Forums/images/ranks/verifier.gif)
![](http://maft.co.uk/avatars/m8tjt.jpg)
Posted: Wed Mar 02, 2016 9:13 am Post subject: |
Kremmen, would it be an idea to check to make sure there are no speed numeric characters in the .csv before the processing? This would alleviate the effect that ashley is experiencing by warning the user to use the converter unzip facility. |
Posted: Wed Mar 02, 2016 10:09 am Post subject: |
It would.
What's annoying is that you thought of it before me
I'm currently debugging the camera counts in the GPX Converter (found the error) and currently working on it.
Doesn't miss any cameras out but it's over counting the duplicates removed. That is because in 14 of the files there are cameras that are within 60 yards of the pseudo Lat Lon in the footer line.
Also a few other small items Dales has found.
My fault because I asked him to test it thoroughly ![Laughing](modules/Forums/images/smiles/icon_lol.gif) _________________ Satnav:
Car Average MPG :
Posted: Wed Mar 02, 2016 11:23 am Post subject: |
Kremmen wrote: | What's annoying is that you thought of it before me | He He ![Very Happy](modules/Forums/images/smiles/icon_biggrin.gif) |
Posted: Wed Mar 02, 2016 8:20 pm Post subject: |
So, have just unzipped via the convertor & tidied up all the file names.
and checked the gpx files for @
Uploaded to my Garmin & will try it tomorrow.
Thanks for all the help guys ![Very Happy](modules/Forums/images/smiles/icon_biggrin.gif) |
Posted: Thu Mar 03, 2016 5:36 am Post subject: |
The next version of the Converter will not run if numbers are found in any csv filename.
It will throw a warning then exit.
The next version is imminent. I have a few small tweaks to make today (3rd) to finalise its compatibility with the new Direction Converter program, also imminent. _________________ Satnav:
Car Average MPG :
Posted: Thu Mar 03, 2016 8:20 am Post subject: |
Looks like it is working as expected now. Only got 1 warning for each of the speed cameras on the way into work, even though I was (a little bit) over the speed limit.
Again, thanks for your help with this. |
Posted: Thu Mar 03, 2016 9:49 am Post subject: |
Kremmen wrote: | The next version is imminent. | Do you have any female voices for it kremmen? |
Posted: Thu Mar 03, 2016 9:53 am Post subject: |
No problem
FYI there will be a new version released soon, once Dales has passed it (them).
The changes will be:
1) Camera counts fixed. The functionality was OK, no cameras missed out, but the total number being displayed as 'read' was wrong.
2) All files in the 3 boxes will display in lower case for neatness.
3) If any CSV files has a number in it the program will warn then terminate. eg: Gatso_50 = reject, Gatso_fifty = OK
4) The previous camera counts has been moved from dynamic to a file. This means that an aborted run or a new program install will still remember the last run stats.
5) Small cosmetic changes to allow a wider process status line(s)
6) The Processing status display changed to reflect the various new files from the CameraManager3 file(s). Used to just show "Processing - Gatso 50". Now displays "Processing - Gatso - gatso_fifty_n.csv" or whatever the actual filename is.
7) There isn't a 7 I can think of but if you spot something it's 7. _________________ Satnav:
Car Average MPG :
Posted: Thu Mar 03, 2016 10:17 am Post subject: |
Kremmen wrote: |
7) There isn't a 7 I can think of but if you spot something it's 7. |
![Laughing](modules/Forums/images/smiles/icon_lol.gif) _________________ Where there's a will ... there's a way. |
Posted: Thu Mar 03, 2016 11:07 am Post subject: |
M8TJT wrote: | Kremmen wrote: | The next version is imminent. | Do you have any female voices for it kremmen? |
The main gpx converter is female voices in the package and Dales has supplied female and male voices for the directional wav's. _________________ Satnav:
Car Average MPG :
stringman Occasional Visitor
Joined: 17/12/2002 11:19:24 Posts: 26 Location: United Kingdom
Posted: Mon Mar 21, 2016 9:38 pm Post subject: |
Guys I wonder if you can help me?
I am using a zumo 390 on my motorbike. It works well using the above method but the warnings (and the direction are just to quite through my helmet)
So I thought I would increase the volume of the warnings.
I downloaded the sounds (with chimes), increased the volume in audacity, and renamed them to match your names (no numbers).
I them converted them with the prog, and uploaded the poi with POILoader.
this flagged up a warning about only having 32 items in a subfolder!!
I ignored this and then tried my route in simulation mode.
I did get a warning but no chimes?
Any ideas what I did wrong and if I should be worried about the 32 item warning?
As an aside is there any way to get things louder ( I am running it through a Bluetooth headset)
Many thanks in advance.
Andy |
