Pocket GPS World :: View topic - PGPSW Cameras to Garmin
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
ashley750
PostPosted: Fri Feb 26, 2016 1:42 pm    Post subject: Reply with quote
There being an extra camera database does make sense. I'll check carefully later, and also look at the gpx files.
Thanks for your help.
ashley750
PostPosted: Fri Feb 26, 2016 8:15 pm    Post subject: Reply with quote
Tonight I have:-
1. removed all the gpi files in the POI folder (Garmin ones had been renamed to oldgpi, but I have now moved them to my PC).
2. searched for any gpi files in internal storage - none found.
3. checked a number of gpx files with Notepad and searched for an "@" - none found.
4. loaded to garmin via POI loader.
5. Proximity Alerts / Audio - set to single tone
6. Proximity Alerts / Alerts - Custom POIs ticked
Down to Portsmouth tomorrow, so will see how it goes.
PostPosted: Sat Feb 27, 2016 6:31 am    Post subject: Reply with quote
If you only have a single camera .gpi and only one entry per camera like my first screenshot then that is correct.
One other thing that I've just remembered. When you run the converter, note the total number of cameras processed/written. Then compare this to the number POILoader says it has loaded.
POILoader also looks in subfolders and can load double cameras. I found this out ages ago when I had a CSV set in a sub folder to my Working Folder.
If you process the whole kit and caboodle then the total number of individual cameras is approaching 20,000. If POILoader reports a greater number......
Satnav:
Car Average MPG :
PostPosted: Sat Feb 27, 2016 9:53 am    Post subject: Reply with quote
I'm getting around 15,000 including pMobiles ??
PostPosted: Sat Feb 27, 2016 11:17 am    Post subject: Reply with quote
That 19,000+ is based on the CameraManager3 files that I'm currently working on with Dales.
The Speed Zoned set could be configured differently.
I'll double check Monday when I'm at the PC that it isn't 15,995 and I'm going senile.
The Converter certainly sweeps up all files, that's been tested to destruction, so it's probably me.
Satnav:
Car Average MPG :
ashley750
PostPosted: Sun Feb 28, 2016 8:54 pm    Post subject: Reply with quote
On the trip to Portsmouth & back I ended up still getting 2 warnings if I was overspeed, the 2nd virtually straight after the 1st.
Today I removed the gpi file from the Garmin & had no speed cameras, so do not have any extra speed camera files on the device.
Looking at the files after using the "CSV to GPX Converter", I noticed there were a number of .prev files. No idea what these are, but when I looked at the contents in Notepad it looked like this:-
Longitude,Latitude,Name
-2.74783,53.32441,"N-GATSO:14@60"
-2.77217,55.74875,"S-GATSO:17@60"
-2.98715,55.8792,"SE-GATSO:67@60"
-2.93653,55.849,"SE-GATSO:70@60"
-2.76429,55.7618,"SE-GATSO:72@60"
-2.53771,54.98042,"E-GATSO:76@60"
-2.41034,54.97009,"W-GATSO:77@60"
-2.6214,55.71961,"W-GATSO:80@60"
etc
Maybe this is the cause of my issues. I'll delete these, use POI Loader to put the cameras back on my Garmin & see what happens.
The number of cameras loaded was 12871, without pmobiles.
PostPosted: Sun Feb 28, 2016 9:48 pm    Post subject: Reply with quote
Without pMobiles mine shows 12,884 having removed 969 adjacent cameras.
dales
PostPosted: Sun Feb 28, 2016 10:52 pm    Post subject: Reply with quote
Could you, by any chance, have ended up with a .gpi file on your device's SD card as well as in internal storage?
The .prev files are perfectly normal and cannot cause duplicate warnings (they are the previous csv files which the converter has now processed to gpx. They are renamed so that PoiLoader cannot read them).
If you have loaded the correct number of cameras, according to PoiLoader, then the fault cannot lie in the files on your PC. That is why I suspect there are old files still on the device or SD card.
Dales
ashley750
PostPosted: Sun Feb 28, 2016 11:21 pm    Post subject: Reply with quote
Hi dales,
I have not used an SD card, and could not find any other .gpi files on the Garmin. When I removed the gpi file with the speed cameras, nothing appeared on the device whilst I was driving.
I found something called current.gpx. Not sure what that is for?
Where else could they be on the device?
dales
PostPosted: Mon Feb 29, 2016 1:16 am    Post subject: Reply with quote
Current.gpx is just a record of your Favourites and your stored routes and tracklogs of where you have been. It is just passive information, and it doesn't generate any warnings.
I'm stuck for what to say now, if your load and data and settings are correct.
Dales.
PostPosted: Mon Feb 29, 2016 6:24 am    Post subject: Reply with quote
I can see exactly what that is........
Those cameras with the @ symbol are not the result of the setup you had in the picture you posted.
The @ symbol will indeed prompt the Garmin to keep on producing warnings if you are overspeed.
With the Overspeed column set to all zeros, as per your screendump, the symbol in the gpx files should be a # not a @. Just having the single @ is the result of having the approach column set to zeros and the Overspeed column having a value.
The program always saves your current options when it exits.
The .prev file is a facility that ties in with the top menu option to see camera changes. Once clicked the program will create a new csv file that can be loaded into Mappoint and will display where all the new cameras are.
I will probably remove that, if no one uses it, because I never use it and it does cause confusion.
Satnav:
Car Average MPG :
ashley750
PostPosted: Mon Feb 29, 2016 9:05 pm    Post subject: Reply with quote
The files with the @ in them were the .prev files. The gpx files are as below:-
I deleted the .prev files and reloaded the gpx, wav & bmp, but have not yet tried it to see if it only gives 1 proximity warning, when going too fast.
PostPosted: Tue Mar 01, 2016 5:40 am    Post subject: Reply with quote
Only 1 warning, regardless of speed, is what it does for me, and what it should do.
I need to double check that gpx output because I wasn't aware that the xsd reference was on each line. May be correct, I'll check the schema requirements.
I worked on the Converter yesterday as I'm linking it to the CameraManager3 fileset. I've removed the .prev facility as it is causing confusion. The next release won't have the 'New Cameras' option.
Satnav:
Car Average MPG :
PostPosted: Tue Mar 01, 2016 11:11 am    Post subject: Reply with quote
That's a shame. Sad
PostPosted: Tue Mar 01, 2016 11:38 am    Post subject: Reply with quote
Oh
I didn't think anyone used the prev files. I haven't used them for a few years now. I've made some changes this morning to be more compatible with the CameraManager files and I removed the prev files option.
I used to get quite a few PM's about them wondering what they were for and could I provide an option not to create them.
Satnav:
Car Average MPG :
Page 6 of 9
22.062 (12 Jun 24)
