Pocket GPS World :: View topic - Mercedes Comand Audio Warning
ROO90
PostPosted: Tue Jan 26, 2016 3:15 pm    Post subject: Mercedes Comand Audio Warning Reply with quote
Have just downloaded the latest speed camera database and the Audio and Visual warnings on to Mercedes Comand ntg 4.5 . This latest download has seen a massive increase in the distance Audio warning, it has gone from one extreme to the other where as before the warning was minimal now the alerts go off about a 2000 mtrs. before the camera. This is causing many false alerts from other cameras not on the road being used. can the Audio distance warning bong be reduced to at least half of what it is now
PostPosted: Tue Jan 26, 2016 3:30 pm    Post subject: Reply with quote
The audio warning timing is nothing to do with the PGPSW data and everything to do with the device it's running on. The database is just a collection of camera locations.
Somehow, the distance warning must have been altered in your device.
ROO90
PostPosted: Tue Jan 26, 2016 3:54 pm    Post subject: Reply with quote
Okay Thanks for prompt reply. will check it out Thumbs Up
PostPosted: Wed Jan 27, 2016 12:55 pm    Post subject: Re: Mercedes Comand Audio Warning Reply with quote
We've actually tweaked the Merc files based on recent feedback. It should now give a 40 second warning - so even for a 70mph camera the maximum would be 1200is meters.
PostPosted: Wed Jan 27, 2016 4:29 pm    Post subject: Reply with quote
It seems like what I said above is a load of blx then? Embarassed
ROO90
PostPosted: Wed Jan 27, 2016 4:57 pm    Post subject: Reply with quote
Have tried to download the latest 14.014 27 Jan 16 speed cameras today. click on same format latest downloads Keep getting Error HTP 404, have tried three different computers , three different browsers with no success
Problem has now been rectified Thumbs Up
ROO90
PostPosted: Thu Jan 28, 2016 6:06 pm    Post subject: Re: Mercedes Comand Audio Warning Reply with quote
MaFt wrote:
Have downloaded the latest database with the 40 sec Audible warning , checked today on a journey of 200 miles, the 40 sec warning is too long and gives massive misleading warnings , it got to the stage I pulled the sad card out. Before I commenced my return journey I loaded the sd again, same results massive irregular warnings , hopefully this will be rectified soon
locksmith
PostPosted: Fri Jan 29, 2016 11:03 am    Post subject: Reply with quote
You can use MB POI loader to alter the files, see here, scroll down to my post near the end!
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=88539&start=120
PostPosted: Fri Jan 29, 2016 3:19 pm    Post subject: Reply with quote
How many seconds warning would you recommend?
locksmith
PostPosted: Fri Jan 29, 2016 3:33 pm    Post subject: Reply with quote
I went for 10 seconds. They are usually just in sight when the bong sounds which is fine for me.
ROO90
PostPosted: Fri Jan 29, 2016 4:40 pm    Post subject: Reply with quote
IMHO I would say 10 secs is too short
PostPosted: Fri Jan 29, 2016 5:12 pm    Post subject: Reply with quote
ROO90
PostPosted: Sat Jan 30, 2016 3:57 pm    Post subject: Reply with quote
Have not been able to reduce the Audible sound warning from the 40 secs set at the last updated download, as previously stated this is far too long giving many false BONGS !! Sad , hopefully to be soon rectified
PostPosted: Sun Jan 31, 2016 12:30 pm    Post subject: Reply with quote
I've now changed the warnings to 20 secs. If you redownload now then this will be active.
Feedback appreciated from all!!!
If you wanted to adjust the warning distance manually then open up the file in a text editor (such as Notepad on Windows [for info I prefer the free Notepad++ on Windows and TextWrangler on Mac]) and do a search/replace on the following text:
Code:
<gpxd:Activity Active="true" Level="warning" Unit="second" Value="20"></gpxd:Activity>
and replace the value of '20' to however many seconds warning you prefer.
ROO90
PostPosted: Mon Feb 01, 2016 12:45 pm    Post subject: Reply with quote
Have this morning downloaded the latest speed camera database with the 20 second Audible warning, This is a massive improvement, done a 40 mile trip , for me this setting is spot on , only one false Bong that was on a road running parallel to journey road with camera visible across open land . I think 10second warning would be too short a distance certainly for mobile camera positions . Thumbs Up
