Pocket GPS World :: View topic - Ash10's Camera Manager Software
Goto page Previous  1, 2, 3 ... 73, 74, 75, 76, 77  Next
BAVC10
PostPosted: Mon Jan 04, 2016 4:40 pm    Post subject: Reply with quote
Does anyone know if Ash10 is still around?
I tried to download the latest version for a new laptop and the link had expired. I have a copy of his files but wondered if anybody had been in contact recently as it would be a shame if he is no longer active in this forum
DriveLuxe 51 LMT D - Firmware 6.80
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3
willton
PostPosted: Tue Jan 12, 2016 2:52 pm    Post subject: Reply with quote
I have it still working - after 'nothing' was changed last time - on Windows 7.
Ive also moved the files to a different machine and it works fine.
However moving it onto Windows 10 causes it to freeze.
willton
PostPosted: Tue Jan 12, 2016 3:32 pm    Post subject: Reply with quote
It got as far as downloading the database and producing the output.csv, but stopped short of producing the individual camera type csv files
That is running it under compatibility mode and as administrator for all users
dales
PostPosted: Tue Jan 12, 2016 4:10 pm    Post subject: Reply with quote
I'm also using Windows 10.
To keep running Ash10 I had to install a virtual machine with VMWare Player (free) and my original Windows XP disc.
It's not difficult, just a little extra admin, and it means I can keep using my directional voice camera alerts.
Dales.
BAVC10
PostPosted: Tue Jan 12, 2016 4:32 pm    Post subject: Reply with quote
I find it does work but whilst it apparently feezes it is actually converting the files, albeit very slowly.
Any change to settings will cause it to "apparently" freeze but it just needs time to do its stuff - on my Windows 10 laptop each download/conversion can take upwards of 7 or 8 minutes, but the end result is spot on - as always!
willton
PostPosted: Tue Jan 12, 2016 5:02 pm    Post subject: Reply with quote
Yes I agree
It worked eventually took about 15 mins to convert the files, watch them updating in File Explorer (Manager!)
Not sure if it needs compatibility or not. Running further tests ...
willton
PostPosted: Tue Jan 12, 2016 5:17 pm    Post subject: Reply with quote
I guess the settings are contained within the exe file.
Im not a programmer but its a shame it wasnt run with an ini file or something so you could edit settings without loading it.
Ive just changed a warning time which should cause it to regenerate the gpx files, but as soon as i hit ok it froze again and ive no idea what its doing
BAVC10
PostPosted: Tue Jan 12, 2016 5:20 pm    Post subject: Reply with quote
Give it 7 to 8 minutes and it should unfreeze.
If you go to the directory on your PC that POI Loader uses you will see the .TMP files being built.
PostPosted: Tue Jan 12, 2016 5:25 pm    Post subject: Reply with quote
As an aside, what does Ash10's prog do that kremmen's doesn't?
willton
Ive ended it and restarted it with the previous Windows 8 compatibility and run as admin and it has responded to my change of warning time and is compiling the gpx files.
So i guess ill leave it at that but just allow an extra 15 mins for the run time.
dales
PostPosted: Tue Jan 12, 2016 5:32 pm    Post subject: Reply with quote
Mobile...sixty...North etc.
PostPosted: Tue Jan 12, 2016 5:50 pm    Post subject: Reply with quote
Ah. I see. Thanks.
C'mon krem ;=)
PostPosted: Tue Jan 12, 2016 5:56 pm    Post subject: Reply with quote
Dales asked me ages ago and sent me the directional voice files but it would involve a complete redesign and rewrite of some core sections. That would be after lengthy analysis.
Something I haven't got time for at the moment.
The Visual Studio VB source code is available to anyone who wants a go though.
willton
PostPosted: Tue Jan 12, 2016 7:59 pm    Post subject: Reply with quote
Im having a play with kremmen's CSV Converter now.
I dont use all the speed zone files, just the Consolidated By Type ones. Ill see how it performs on my 3760T
PostPosted: Tue Jan 12, 2016 8:11 pm    Post subject: Reply with quote
How does it perform on your W10 machine? Or was it BAVC10 with W10?
Page 74 of 77
