Pocket GPS World :: View topic - CamerAlert Settings
CamerAlert Settings
leehazzo
PostPosted: Fri Nov 13, 2015 9:44 pm    Post subject: CamerAlert Settings Reply with quote
Hi all.
Wonder if someone could please share with me the optimum warning settings for CamerAlert.
I'm trying to move the "sliders" in the advanced settings menu to limit the amount of "False" alerts from cross roads and adjacent roads I travel on....
Direction Difference......
Warning cone......
Warning sensitivity......
Thanks in advance
Lee
PostPosted: Fri Nov 13, 2015 11:06 pm    Post subject: Reply with quote
I'm not an android user, so treat me with only a little attention!
There are NO optimum settings, because my optimum settings are NOT yours. The idea of providing adjustable settings is so that the user can determine his/her own preferences.
I suggest you read the manual which explains what the settings do, then fiddle with them to get your favourite results.
Be aware that you can setup to virtually eliminate EVERY false warning, but the result will be missing a lot of (adequate) true warnings.
PostPosted: Sat Nov 14, 2015 12:21 am    Post subject: Reply with quote
How do you do that Dennis? Forget to restart it after it has timed out whilst stationary?
Privateer
PostPosted: Sat Nov 14, 2015 12:05 pm    Post subject: Reply with quote
Whilst I'm an iOS user (like Dennis) I use CamerAlert on its default settings and ignore any false warnings.
I use the police siren as a forewarning to get my attention and then I listen to the spoken warnings because 9 times out of 10 CamerAlert will be running in the background with my SatNav app running in the foreground.
In the UK, the database is very good (it's been running for over 13 years and is updated on a daily basis with weekly releases). The warnings you get are highly likely to be correct but you can get get warnings for other road(s) that run parallel to the road that you're on and those roads may have a different speed limit. Having CamerAlert warn of only cameras in your direction helps. Otherwise just use the warning as a note to check your speed.
If you find that warnings are too much then you can obviously adjust them but then you run the risk that the settings for CamerAlert whilst driving in one area may be inappropriate for driving in another area.
Robert.
Garmin Camper 770 LMT-D
PostPosted: Sat Nov 14, 2015 5:52 pm    Post subject: Reply with quote
Simples - set those three things to almost (or actually) zero.
PostPosted: Tue Nov 17, 2015 8:04 pm    Post subject: Re: CamerAlert Settings Reply with quote
leehazzo wrote:
Hi all.
Warning cone......
Thanks in advance
Lee
I knock each down by 5 from the default so, top to bottom: 40, 40, 45
23.092 (10 Sep 25)
