Kremmen Pocket GPS Verifier
Posted: Fri Nov 13, 2015 5:44 am Post subject: |
The power from a USB is only a trickle charge. When in full navigation mode my guess is that it's using more than it's charging.
Plus, as mentioned, it often gets confused whether it's in a car or connected to a computer. _________________ DashCam:
Viofo A119 V3 |
SamIOW Occasional Visitor
Posted: Fri Nov 13, 2015 9:05 am Post subject: |
Kremmen wrote: | The power from a USB is only a trickle charge. When in full navigation mode my guess is that it's using more than it's charging.
Plus, as mentioned, it often gets confused whether it's in a car or connected to a computer. |
Thanks for that
I did realise that it was only a trickle charge as the main power lead is 12 volts. BUt in my personal case I had no other choice as I needed the Satnav and the only way that I could use it was by using the usb lead which didn't keep shutting down!!. Hopefully when they finally manage to sort out the software I will have a fully functioned satnav which is fit for purpose!!!! |
Posted: Fri Nov 13, 2015 9:14 am Post subject: |
I think unless you can find a way to get a proper Garmin 12v to 5v TA cable hooked up you will probably continue to have issues. _________________ DashCam:
Viofo A119 V3 |
Posted: Fri Nov 13, 2015 9:19 am Post subject: |
It is in Garmin corner now, If they can't resolve it in a reasonable time, then I will get my money back and go back to a TomTom, although I quite like the 2699. |
Posted: Fri Nov 13, 2015 4:46 pm Post subject: |
Just been on the phone to Garmin Support and this what they have had to say.
The problem is the updated software which is V7.80 (also could me the maps too ) they had thought this would have fixed it but it hasn't.
This is very big problem in that there are loads of people with the same problem as me with the unit shutting down after a few minutes , She told me that they have sent the files which I had sent them plus all the others to the software team in the US.
I asked them when could I expect a fix and was told that they have got no idea but it would be days opposed to weeks, ( I hope ) Not sure what I am going to do as I quite it but surely they should have recalled all the unit and take them of the shelves if they are not fit for purpose!!! |
Posted: Fri Nov 13, 2015 5:29 pm Post subject: |
I can't understand why the 2599 is OK but the 2699 is having issues?
Just a larger screen ! _________________ DashCam:
Viofo A119 V3 |
Posted: Fri Nov 13, 2015 5:33 pm Post subject: |
Kremmen wrote: | I can't understand why the 2599 is OK but the 2699 is having issues?
Just a larger screen ! |
I don't either, But just wondered what version software you have ?
I am only repeating what their support told me |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4462 Location: West Sussex
Posted: Fri Nov 13, 2015 5:34 pm Post subject: |
Me neither. Indeed the software is common to numerous devices. Sometimes Garmin customer support get it wrong  _________________ Where there's a will ... there's a way. |
Posted: Fri Nov 13, 2015 6:32 pm Post subject: |
I'll have a look on the unit tomorrow to see what it reveals.
It's out in the garage and it's dark now  _________________ DashCam:
Viofo A119 V3 |
Posted: Fri Nov 13, 2015 8:20 pm Post subject: |
sussamb wrote: | Me neither. Indeed the software is common to numerous devices. Sometimes Garmin customer support get it wrong  |
They might well have but I doubt even they could get the number of other people wrong, I can only repeat what not just one of them but different support people have told me  |
Posted: Sat Nov 14, 2015 11:07 am Post subject: |
hardware version V4 SA3 8GB 128MB W07 BT DAB
software version 7.80
audio version 2.10
voice command 2.20
text version 2.30
GPS firmware 3.05.10
bluetooth firmware 3.0.11 P32
TSC version 3.171.019
FMI 3.1 _________________ DashCam:
Viofo A119 V3 |
Posted: Sat Nov 14, 2015 10:12 pm Post subject: |
Thanks for that, It is really bizarre....... as you say yours is working fine. all I hope is that they sort out mine and the other really quick.  |
Posted: Sun Nov 15, 2015 6:35 am Post subject: |
... or ask for a 2599 _________________ DashCam:
Viofo A119 V3 |
Posted: Sun Nov 15, 2015 1:16 pm Post subject: |
Kremmen wrote: | ... or ask for a 2599 |
Trouble is I prefer the 6 inch version. which suits me.  |
jhiker Occasional Visitor
Posted: Tue Nov 24, 2015 12:23 pm Post subject: |
Well, my 2599LMT-D switched off and rebooted several times on Saturday in Liverpool city centre. It wouldn't stay switched on. I was using the 12v mains/antennae lead and had it plugged in.
In the end I had to switch off manually and input the destination postcode again. I was holding the power key down for so long at the lights I may have inadvertently done a 'soft reset' but I can't be sure.
If I recall, it has switched itself off once before in the few weeks I've had it.
Was a bit disconcerting really. |
