Pocket GPS World :: View topic - NT2016.20 is out
NT2016.20 is out
alan_sh
PostPosted: Thu Oct 29, 2015 4:59 pm    Post subject: NT2016.20 is out Reply with quote
As it says - I've just updated my two Zumo 660's.
Alan
PostPosted: Thu Oct 29, 2015 5:23 pm    Post subject: Reply with quote
Seems Garmin with the Move to 3 updates a year for the NTU version may now be releasing the NT version at around the same time, guess we'll know when 2016.30 is released Smile
Roy124
PostPosted: Thu Oct 29, 2015 5:37 pm    Post subject: Reply with quote
Gave it a road test today:
A speed camera shown on original release and also 2016.10 is no longer shown.
The current speed symbol has changed from the red/white/black road symbol to a simple black bordered rectangle showing for instance LIMIT 30.
My "Home" setting was wiped from memory and in the Where to categories it was Greyed Out. It was easy to reset it.
PostPosted: Thu Oct 29, 2015 5:51 pm    Post subject: Reply with quote
Good result then. Not.
PostPosted: Thu Oct 29, 2015 8:14 pm    Post subject: Reply with quote
@Roy124
I'm confused as speed cameras aren't part of the map download?
If the speed symbol has changed I would guess you've selected a different locale, sounds like the US one?
Roy124
PostPosted: Mon Nov 09, 2015 9:02 pm    Post subject: Reply with quote
My 3598 was new in Dec 14 and had a speed cam database installed; this is a non-subscription ie it is not updateable.
I undated the mapping on receipt and later to 2016.10. in both cases the speed cam data remained. Now, with 2016.20 the database has gone.
It is possible that Garmin 'kill' the free speedcam data 12 months after the original files.
You mentioned that the Limit Speed rather than Speed Limit display may e because of American settings. Certainly after I installed 2016.20 the default voice became American and I changed that back but most settings remained.
I have looked through the setting menu and can find no reference to a display language. It there a hidden item somewhere?
PostPosted: Mon Nov 09, 2015 10:11 pm    Post subject: Reply with quote
If you made a back up copy of all your files, which you should always do, try copying the speed camera files back, they should still work.
Unfortunately if you've selected the American locale while you can change some things like the voice you can't do much else. You need to reset the locale by doing a master reset.
Roy124
PostPosted: Mon Nov 09, 2015 11:02 pm    Post subject: Reply with quote
Thank you. Not sure how I could have set it at US.
