Pocket GPS World :: View topic - Voice Alerts - Nuvi 2599
tuftyjack
PostPosted: Sun Oct 18, 2015 10:46 am    Post subject: Voice Alerts - Nuvi 2599 Reply with quote
I cannot get Custom voice alerts to work on my new 2599. Which POI folder should they go in? I have Garmin/POI and a separate POI folder. The camera database works fine but only "boings" sound. I am confused.
PostPosted: Sun Oct 18, 2015 11:11 am    Post subject: Reply with quote
Not sure why you have a Garmin/POI folder, the speed camera files should be in the separate POI folder.
PostPosted: Sun Oct 18, 2015 11:56 am    Post subject: Reply with quote
Once I've finished the Converter update I'll do a new guide for the stock CSV files procedure.
In the meantime have a look at this:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=95881
Note specifically the SOX.exe, files locations and POIloader. Thise bits don't change for CSV v GPX
tuftyjack
PostPosted: Sun Oct 18, 2015 1:20 pm    Post subject: Voice Alerts - Nuvi 2599 Reply with quote
Thanks for that. Both folders were there when I got it. Still won't work after removing Garmin/POI folder. I have an card coming, so I intend to start from scratch and put the files on that. Can you direct me to the video for installing voice alert files?
PostPosted: Sun Oct 18, 2015 2:02 pm    Post subject: Reply with quote
It's really worth while investigating kremmen's CSV to GPX converter. It gives a far better speedcam experience that the bog standard Garmin offering. kremmen has included a pretty good help file that steps through the processes required and is well worth the extra effort involved in learning how to use it. It's not that difficult, honestly. It just appears to be harder than it really is and once you get the hang of it, it's a piece of cake.
PostPosted: Sun Oct 18, 2015 3:46 pm    Post subject: Reply with quote
Whether you use CSV or GPX via the converter you don't need to confuse matters with a SD card.
POILoader puts the resultant .GPI file on the device in the correct place. If POILoader is not producing voice alerts then the problem is on the PC.
tuftyjack
PostPosted: Mon Oct 19, 2015 8:02 am    Post subject: Nuvi2599 Voice alerts Reply with quote
Could my problem be that the alerts are .mp3 format?
PostPosted: Mon Oct 19, 2015 8:49 am    Post subject: Reply with quote
Yes! Later nuvis need wav format.
tuftyjack
PostPosted: Mon Oct 19, 2015 2:06 pm    Post subject: Nuvi alerts Reply with quote
For sussamb. Tried a reload and found: 1. poiloader placed speedcams in Garmin/POI NOT POI. 2. Converted mp3 voice alert to Wav-failed to convert and load on POIloader. 3. Pgpsw cams work except for voice alerts. I am losing the will to live. Tomtom system was way easier.
PostPosted: Mon Oct 19, 2015 2:27 pm    Post subject: Reply with quote
POILoader will put the files where you want them, and I think defaults to the last location it used. They need to be in their own folder, not in Garmin. The reason the initial default is Garmin/POI is that it was originally designed/written for older Garmin devices, which have a different folder structure.
Can't help much with voice files as I don't use them, the Garmin 'bong' is enough for me to wake up and take note Laughing
PostPosted: Mon Oct 19, 2015 2:34 pm    Post subject: Reply with quote
You don't need to convert the MP3 to WAV. The WAV files are downloaded in the PGPSW zip package if you select that option.
For ease go for the Garmin POILoader UK Speed Zoned set.
Once unzipped, in the folder where you're unzipping to, you should have each camera type with 3 matching files.
One set for example is: (Gatso 20 MPH set)
pocketgps_uk_gatso_20.csv
pocketgps_uk_gatso_20.wav
Next check that you have SOX.exe in the same folder where POIloader.exe is located.
That's it, job done, run POILoader.
tuftyjack
PostPosted: Mon Oct 19, 2015 2:39 pm    Post subject: Nuvi voice alerts Reply with quote
Yippee it is working. It boiled down to sox.exe. I reloaded and it worksnow. Thanks for your expert help.
PostPosted: Mon Oct 19, 2015 6:32 pm    Post subject: Reply with quote
It would have likely have been because you had MP3 and not WAV audio files
