Pocket GPS World :: View topic - Go 520 Unresponsive
Go 520 Unresponsive
Crocodile
PostPosted: Mon Aug 17, 2015 7:24 pm    Post subject: Go 520 Unresponsive Reply with quote
I have a Go 520 that is completely unresponsive. Touch screen won't register anything & the device seems to have no GPS fix when connected to Home & using Operate My Device or whatever it's called. Position remains locked several miles away.
I've tried a long press of the reset button & deleted & re-installed the app but to no avail. I've also tried the clear flash tool. Anyone have any ideas before it heads towards the bin?
If it's relevant, it did suffer from the misalignment of the touch screen issue around a year ago which was fixed with the text file, whose name escapes me for the minute.
PostPosted: Tue Aug 18, 2015 6:54 pm    Post subject: Reply with quote
I think Operate my GO is mostly Virtual, not 100% actually operating the 520.
Anyway, could you try running it using an SDHC card? Copy everything to PC, then to a blank SDHC and try then.
Otherwise it sounds like terminal.
AliOnHols
PostPosted: Tue Aug 18, 2015 7:18 pm    Post subject: Reply with quote
There used to be a solution posted here quite often to a non-responsive screen issue.
Get a piece of thin card/thick paper and run it around the gap between the screen and the frame.
It is possible for some dust to get into the gap and confuse the touch screen.
Garmin Nuvi 2599
SatMap Active 10 & 20.
Crocodile
PostPosted: Tue Aug 18, 2015 7:23 pm    Post subject: Reply with quote
Thanks guys.
Pretty sure Operate My Go uses the GPS receiver. I'll try & SD card & report back.
Don't think it's a problem with dirt in the digitizer as I've had the unit stripped apart & cleaned all around the screen bezel.
Crocodile
PostPosted: Tue Aug 18, 2015 7:57 pm    Post subject: Reply with quote
Installed to SD & no difference. Device is still issuing instructions so seems to be functioning on some level. Maybe the digitizer has had it?
Can't see it being economical to repair.
PostPosted: Tue Aug 18, 2015 8:00 pm    Post subject: Reply with quote
Does economy come into it? The more recent TomTom devices don't hold a candle to it.
theripper
PostPosted: Wed Aug 19, 2015 9:05 pm    Post subject: Reply with quote
PM me your location before you bin it I think I may have a complete screen lying around somewhere.
theripper
Crocodile
PostPosted: Thu Aug 20, 2015 6:58 am    Post subject: Reply with quote
theripper
Thanks - done. Smile
PostPosted: Thu Aug 20, 2015 9:23 am    Post subject: Reply with quote
You could also add your approximate location etc. in your profile.
23.012 (08 Jan 25)
