Pocket GPS World :: View topic - 44X44 and 24X24 Icons courtesy of GerryC
lillyelse
PostPosted: Wed Jul 22, 2015 12:00 am    Post subject: 44X44 and 24X24 Icons courtesy of GerryC Reply with quote
Can I use these on a Garmin Nuvii 3598?
What is the procedure?
I normally use the POILoder version but don't usually download the voice files. Can I use the voice files?
Someone on the site suggests that triple .bmp files are required in the custom poi database. Is this correct and what are these?
Appreciate any help, for which many thanks in advance.
PostPosted: Wed Jul 22, 2015 4:59 am    Post subject: Reply with quote
I've posted a couple of writeups on these fairly recently. They should help.
lillyelse
PostPosted: Wed Jul 22, 2015 10:17 am    Post subject: 24X24 &44X44 Icons for Nuvii3598 Reply with quote
Thanks Kremmen.
One further request;
Can you point me at the particular write-ups that you posted?
There is an awful lot of material on the site and it would save me an awful amount of time if I could go directly to the articles.
Thank you once again for your kind reply.
PostPosted: Wed Jul 22, 2015 11:01 am    Post subject: Reply with quote
The latest one is the 'CSV to Garmin' in this subsection. That has most of it.
I'm on a tablet today and links are tricky.
lillyelse
PostPosted: Wed Jul 22, 2015 4:13 pm    Post subject: 24X24 & 44X44 Icons Reply with quote
Many thanks again Kremmen.
Metblackrat
PostPosted: Wed Jul 22, 2015 4:57 pm    Post subject: Reply with quote
I have a full set of transparent (only the round sign, not the background visible) 44x44 icons but cannot work out how to upload them!
I've emailed them to MaFt. Hopefully they can be uploaded.
PostPosted: Thu Jul 23, 2015 4:48 am    Post subject: Reply with quote
Sounds interesting.
I did my first journey with the 44's yesterday and the larger icons are better as they stand out more.
Metblackrat
PostPosted: Thu Jul 23, 2015 5:03 pm    Post subject: Reply with quote
All my icons are 44x44 and transparent. Examples can be seen in this thread.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=95688
All you need to do is change the bits you don't want to see to true magenta.
PostPosted: Thu Jul 23, 2015 7:16 pm    Post subject: Reply with quote
I can only see one picture and that has no speed icons I can spot.
Metblackrat
PostPosted: Fri Jul 24, 2015 6:32 am    Post subject: Reply with quote
The 50 sign on the left by Laurel Gardens is a camera icon, not the one for the current speed limit.
PostPosted: Fri Jul 24, 2015 1:34 pm    Post subject: Reply with quote
Just converted the background of mine to RGB 255,0,255 and they now have a lovely magenta background. What could possibly go wrong? Or more to the point, what am I doing wrong?
Metblackrat
PostPosted: Fri Jul 24, 2015 3:32 pm    Post subject: Reply with quote
Are you saving them as a 24 bit .bmp file?. Any higher and they don't work.
Metblackrat
PostPosted: Fri Jul 24, 2015 3:50 pm    Post subject: Reply with quote
Put my icons in Dropbox. Feel free to use them. They work fine on my 3597.
https://www.dropbox.com/s/jvwr4ndvhem8w19/44x44.zip?dl=0
PostPosted: Fri Jul 24, 2015 4:17 pm    Post subject: Reply with quote
Hi Met.
Not sure about bit depth. Just flood filled the background then saved. Using The Gimp, if it makes ant difference.
Thanks for the link. I'll pop along there in a bit and pick them up.
23.022 (12 Feb 25)
