Pocket GPS World :: View topic - Couple of noob 2599 questions
tenchy
PostPosted: Tue Jun 02, 2015 11:11 pm    Post subject: Couple of noob 2599 questions Reply with quote
Got my shiny new 2599 now.
Every time I turn it on the don't operate by driving comes up.
Can it be disabled?
Also, last time I turned it on it went through the eula thing again. Not language, but eula. Is that normal?
It did take longer to come on and showed the garmin logo for probably 20 secs or so.
I just turned it off normally I thought.
Talking of which, I understand that it's usually on a standby, so it starts quickly. But can be turned off more fully. How do you do both?
Each time it starts voice command banner pops down at the top of screen briefly. Can it be disabled?
I tried traffic, in the house, not on the mount or any cable. It said I needed something else for that?
Is the antenna in the cable?
PostPosted: Wed Jun 03, 2015 4:52 am    Post subject: Reply with quote
To remove the EULA warning/info you need to plug the unit into a PC and register it online. If you have done and it's still showing you can, again with a PC, remove the EULA file(s) which also stop it displaying.
The nag screen is a fact of life but don't press agree as it soon goes away on it's own, probably a minute or 2 once you are moving.
You won't get traffic indoors unless you are using Smartlink.
Satnav:
Car Average MPG :
PostPosted: Wed Jun 03, 2015 6:43 am    Post subject: Reply with quote
You also won't get traffic outdoors unless your nuvi is powered by the correct cable, as it contains the antenna.
EULA will disappear after a while too, I think once you've had a firm satellite lock.
To switch off completely press and hold the off switch until you see a message asking you 'Turn off the device?'. It's worth doing that occasionally or if your nuvi misbehaves as it forces a 'cold boot'.
tenchy
PostPosted: Wed Jun 03, 2015 11:22 am    Post subject: Reply with quote
Thanks guys. All useful to know. I did think maybe antenna was in cable, but I have looked at so many new to me things this last few days it's a bit of a blur!
I have garmin express installed, but not had a good slot to go for plugging it in for updates etc. Probably tomorrow. Hopefully no new threads from me about that!!
22.055 (29 May 24)
