asterraine Occasional Visitor
Posted: Wed Sep 22, 2004 10:07 pm Post subject: TOMTOM GPS refresh rate |
Hi.
I'm using tomtom3 on an Ipaq 3970 with a rikaline 6010 wired GPS. Since upgrading from tomtom2, I've noticed the blue arrow thing seems to be about 1second (10-20 metres) behind my actual position. I never had this problem using the same equiptment and tomtom2.
I spoke to tomtom and they suggested a complete reload. I've tried this but it doesn't make any difference.
I've tested my configuration with a colleagues tomtom3 on HP2260 and bluetooth and the GPS positions are almost identical. It looks like tomtom3 is taking the rikalines previous GPS position and displaying it, rather then the latest reading, hence the 1 second delay.
Is this a known problem or is there a fix for this. I'm continually going round traffic islands twice!!!!!
Thanks. |
lbendlin Pocket GPS Staff
Posted: Wed Sep 22, 2004 11:45 pm Post subject: |
We have seen this happening when the receiver is run at "wrong" speed. Can you confirm that your Rikaline is set to NMEA 4800 at COM1: ? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Thu Sep 23, 2004 10:18 pm Post subject: |
How do I check that?.
On the PDS, I've been into the GPS Status, GPS, and changed the top box from 'Rikaline GPS-6010' to 'NMEA 0183v2 4800' but I still think it behind the actual position.
Is there anything else I should be changing? |
Beefy Regular Visitor
Joined: Aug 06, 2004 Posts: 107 Location: Bucks, United Kingdom
Posted: Thu Sep 23, 2004 10:47 pm Post subject: |
I had the same problem, the way I got round it was to install TomTom on my main memory and the maps on my SD card, also to reduce the number of POI's that I was displaying. If you have a lot of POIs types checked for display it eats up the processing power of the PDA. I reduced it to around 20 POI types and it works fine. _________________ Beefy
High Quality Pubs - http://www.pocketgpspoi.com/reviews/tomtompoi/High_Quality_Pubs.zip
TomTom ONE |
Posted: Fri Sep 24, 2004 7:31 am Post subject: |
The software is loaded to the IPAQ main memory, and the maps are on a 256MB SD card. I've also had them loaded on a 128MB SD card but it made no difference.
I've only got the standard POI's loaded that come with TOMTOM as default. There are about 4 selected for view and I'll try turning these off with the new GPS settings. I did turn them off once before when the GPS settings were set to Rikaline 6010 but it made no difference.
Thanks. |
Posted: Fri Sep 24, 2004 8:07 am Post subject: |
After what you have said this sounds more to do with what Lutz was talking about.
Have you run something like Winfast Navigator to reset the GPS with it's factory settings and correct baud rate. Then make sure that you disconnect Winfast from the GPS before trying TT again. _________________ Beefy
TomTom ONE |
