Pocket GPS World :: View topic - EMTAC BT GPS aerial
EMTAC BT GPS aerial
elbon50
PostPosted: Mon Apr 20, 2015 3:25 pm    Post subject: Reply with quote
aj2052 wrote:
Your welcome, Unfortunately at the moment its a case of you see it when not looking for it but cannot find when you do look for it, will post when I find.
I know the feeling all to well Crying or Very sad
elbon50
PostPosted: Mon Apr 20, 2015 7:46 pm    Post subject: Reply with quote
This one's a bit less fuzzy
Zoom is your friend
3.2mm socket internal dia (as previously said)
Peter
elbon50
PostPosted: Tue Apr 21, 2015 4:48 pm    Post subject: Reply with quote
Went to Halfords & Currys today & showed them the EMTAC
Halfords were absolutely no help at all
The youth said they do not deal in external aerials
(only interested in selling brand new SatNav Sad )
Currys were a little more helpful
They gave me the contact details of their Partmaster team of "knowhow experts"
Will give them a try ASAP
Peter
aj2052
PostPosted: Tue Apr 21, 2015 4:54 pm    Post subject: Reply with quote
I should check, the barrel dimension for a cmx connector is 3.66mm, if you google cmx connector their are various dimensional drawings shown
Moto G5s Plus, Sygic 17.4.8
elbon50
PostPosted: Tue Apr 21, 2015 5:10 pm    Post subject: Reply with quote
Many thanks AJ
Will do that Thumbs Up
Peter
aj2052
PostPosted: Tue Apr 21, 2015 5:15 pm    Post subject: Reply with quote
have a look at this one , it does mention emtac,
http://www.amazon.co.uk/GPS-ANTENNA-WITH-MCX-A-PLUG/dp/B00FAK2UP8/ref=sr_1_7?
aj2052
PostPosted: Tue Apr 21, 2015 5:25 pm    Post subject: Reply with quote
BINGO, after fruitless searches. decided to have another quick look and found my gps receiver, it is magnetic and plug is about 3.2mm, will try and put picture up in while.
Correction dim Approx 2.4 stepping upto 3.41
aj2052
PostPosted: Tue Apr 21, 2015 5:52 pm    Post subject: Reply with quote
Here it is:
[img]http://s368.photobucket.com/user/aj2052/media/gps.jpg.html[/img]
elbon50
PostPosted: Wed Apr 22, 2015 9:33 am    Post subject: Reply with quote
Many thanks for all the trouble you've gone to with this AJ Smile
It's a bit baffling that the plug on your aerial measures only 2.4 mm approx Confused
Will get back to you when I've looked into this a bit further
Peter
elbon50
PostPosted: Wed Apr 22, 2015 11:16 am    Post subject: Reply with quote
I've found this writeup by Mike Barett of Pocket GPS World Smile
http://www.pocketgpsworld.com/emtac.php
This is this is the same model as mine
He says it is an MCX connector
aj2052
PostPosted: Wed Apr 22, 2015 12:14 pm    Post subject: Reply with quote
It has two further steps, 2.4 being the smallest around the centre pin, it looks like a bit of a universal fitting.
elbon50
PostPosted: Wed Apr 22, 2015 5:47 pm    Post subject: Reply with quote
MCX plug & jack should fit together then Confused
I could send you a padded bag with some stamps on ?
Or: you may like to let me know the cost & I would PayPal it to you
Peter
aj2052
PostPosted: Wed Apr 22, 2015 6:57 pm    Post subject: Reply with quote
Just done some further searches and it appears the mio external gps uses a mmcx plug which is a miniature version of the mcx and barrel size is 2.4mm, also came across a couple of sellers showing compatible lists and unfortunately Emtac does not appear on them.
elbon50
PostPosted: Wed Apr 22, 2015 7:53 pm    Post subject: Reply with quote
Never mind, I'll continue searching around for information
May send for a MCX aerial from eBay now that I've found that PGPSW writeup saying that MCX is the correct one
They are only about a fiver on there
Thank you very much once more for all the trouble you've gone to for me
Peter
PostPosted: Thu Apr 23, 2015 7:03 am    Post subject: Reply with quote
Sounds like it's worth a punt. You can always return it for refund if it doesn't fit (and if you can be bothered).
Page 2 of 3
