Pocket GPS World :: View topic - newbie......bluetooth gps settings
newt
PostPosted: Wed Sep 22, 2004 5:18 pm    Post subject: newbie......bluetooth gps settings Reply with quote
hi.....plan to use my ipaq 1940 with a bluetooth receiver and tt 3.......what settings do i use in the gps setup.......
i have
COM 3
BLUETOOTH SERIAL COM 8
BLUETOOTH SERIAL COM 5
S2410 IRDA2410
S2410 COM 0
SERIAL ON USB
also which gps driver would you recommend to use......would 2.07 work
thanks
ivan
PostPosted: Wed Sep 22, 2004 9:20 pm    Post subject: Reply with quote
hi there
dont know if this helps but i got 1940 and got the tomtom3 gps reciever and works well together !
so on that i would say stick with the best !
cheers
ivan
Privateer
PostPosted: Wed Sep 22, 2004 11:00 pm    Post subject: Reply with quote
Hi Newt,
TT GPS Driver 2.07 is a good one to use.
NMEA 0183v2 38400 is a good start too.
Try either of your Bluetooth COMs.
Don’t forget to pair you BT receiver with your iPAQ 1940 as well.
Robert.
Garmin Camper 770 LMT-D
Baldlygo
PostPosted: Thu Sep 23, 2004 9:54 am    Post subject: Reply with quote
Like Ivan I also have iPaq 1940 with TT3 Bluetooth.
It installed well out of the box and all worked without me knowing how!
I did run into problems when I also installed Memory-map.
The default TT3 installation automatically picked up NMEA - Bluetooth COM8 which is fine if you only run TT however TT locks the port COM8 (even when it is not running).
TT support sent me an older GPS driver which now allows me to run both apps. (one at a time of course!).
22.063 (19 Jun 24)
