Pocket GPS World :: View topic - Garmin Nuvi 3598lmt-d - help required with speed POIs
Goto page Previous  1, 2
Dabri
PostPosted: Tue Jan 06, 2015 4:15 pm    Post subject: Reply with quote
I think we have moved away from our original (sub) topic about using 44 x 44 icons. Kremmen kindly put up my screen view following a query about 3598-acceptable icon sizes; shall we stop now?
Dabri.
Navman iCN530T; Garmin 760T v4.80; Garmin 765T v4.00; Garmin 2460LMT v3.60; Samsung S3;
Garmin 3598LMT-D v5.50; Samsung J6; Garmin DriveSmart76 LT-D v7.90; Samsung A52.
Chopsie
PostPosted: Fri Jan 09, 2015 6:04 pm    Post subject: Reply with quote
I appreciate everyone who has contributed to a solution but am still a little unclear.
My critical issue is getting the voice files to work.
I am able to download PGPS speed files that include either wav or mp3 voices. When I download with mp3 voices it appears that the POI loader accepts them. When I download with wav files the POI loader rejects them.
Are you suggesting that I need the wav files but need to use sox.exe to convert the wav files in the POI Loader root directory?
Kremmen - To answer your question you can load the POI's via the POI loader manual option. This gives you the opportunity to change the speed and distance to the POI.
I could not find anything else on the forum that covers this issue but as a newbie to the forum may not be searching for the right thing!
Wishing I had stuck with my old TT700! It seems to deal with POI's much better and gives you options as to which you have displayed.
I also get an annoying beep every time you go over the speed limit by 1 mph. Anyone know how to stop this from going off?
BAVC10
PostPosted: Fri Jan 09, 2015 6:17 pm    Post subject: Reply with quote
Yes, Sox.exe needs to be in the same directory as the .wav files and poiloader.exe. It should then run fine.
DriveLuxe 51 LMT D - Firmware 6.80
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3
PostPosted: Fri Jan 09, 2015 6:32 pm    Post subject: Reply with quote
Yes, should be in Settings, Map & Vehicle, Audible speed alerts
Chopsie
PostPosted: Fri Jan 09, 2015 7:40 pm    Post subject: Reply with quote
Much appreciated.
Tried the sox.exe file in the POI Loader director and downloaded the wav file format. It now appears to be working but will get a better idea when I go out past a speed camera. Just tried it on simulator.
The audible speed alerts are showing as disabled but it still beeped on me earlier today! I will see what happens next time I am out.
PostPosted: Fri Jan 09, 2015 7:50 pm    Post subject: Reply with quote
Is there a definitive link to the 'old' sox.exe that is needed to make stuff work. It has oft been repeated 'use an old version' with no indication from where it is available. Would it not be helpful if there were a link to the correct version in the Garmin speedcam setup help
Chopsie
PostPosted: Fri Jan 09, 2015 10:00 pm    Post subject: Reply with quote
Try this. It just worked for me.
http://garmin.gps-data-team.com/get.php?download=O29/software/sox.exe
PostPosted: Fri Jan 09, 2015 11:45 pm    Post subject: Reply with quote
Thanks. But what I meant was a link in a central place that everyone could find without having to wade through loads of posts to fid the right link. Very Happy
PostPosted: Sat Jan 10, 2015 7:14 am    Post subject: Reply with quote
BAVC10 wrote:
Sox just needs to be in the poiloader.exe folder, the wav files need to be in the same location as the csv/gpx and bmp files.
Chopsie
PostPosted: Sat Jan 10, 2015 10:11 am    Post subject: Reply with quote
Thank you, I realised that.
alan_sh
PostPosted: Sat Jan 10, 2015 3:41 pm    Post subject: Reply with quote
That doesn't take me to anywhere that I can see sox.exe
Alan
PostPosted: Sat Jan 10, 2015 4:01 pm    Post subject: Reply with quote
That's why I was suggesting a definitive link somewhere central and the Garmin installation guide seemed to me to be as good a place as any and a lot better than most. Rolling Eyes
There must be dozens of links scattered around the Garmin posts here, some of which work, some of which don't and some of which lead you to the wrong version.
Chopsie
PostPosted: Sat Jan 10, 2015 4:06 pm    Post subject: Reply with quote
Try running it from the link available on this page:
http://www.gps-data-team.com/pda-gps-navigation/topic/2500.html
PostPosted: Sat Jan 10, 2015 4:20 pm    Post subject: Reply with quote
At least that link leads to a sox.exe download. I don't actually want it as I don't have a Garmin. I just brought up the subject as so many people ask from where they can get a version of sox.exe that actually works. Apparently some don't.
Page 2 of 2
