Pocket GPS World :: View topic - Garmin CSV to GPX Converter
Goto page Previous  1, 2, 3 ... 13, 14, 15 ... 73, 74, 75  Next
dales
PostPosted: Mon Jan 05, 2015 8:01 pm    Post subject: Reply with quote
I've sent you a pm with the dropbox link for the voice warnings I made.
With cameras analysed by type and by direction and by speed, I have over 100 categories for the UK. So I put them in the root of the folder, to avoid problems with the limit on subcategories (see my post in September, earlier in this thread).
Dales
meditek
PostPosted: Tue Jan 06, 2015 1:08 pm    Post subject: Reply with quote
Problem solved.
meditek
PostPosted: Tue Jan 06, 2015 9:12 pm    Post subject: Reply with quote
Thanks Krem for a useful bit of software. Once I did exactly what I was told it worked perfectly and now my cheapo Nuvi 40 is doing everything that my farcifully expensive CIC BMW kit can't.
PostPosted: Wed Jan 07, 2015 7:26 am    Post subject: Reply with quote
Just for an update about the above request from dales.
I have been looking at the suggestion to include the direction of the camera in the spoken alert(s) to help overcome the issue with Garmin not being directional.
The changes required would be significant and certainly not something I could achieve in the short term.
I haven't given up but it's on the back burner.
meditek
PostPosted: Wed Jan 07, 2015 2:32 pm    Post subject: Reply with quote
The biggest problem, even if you could hack Garmin's compass code, are these 'white vans' the police are using these days. They're stuffed with more electronics than a U2 and have 360 degree surveillance i.e. it matters not what direction you're traveling in as I found to my cost.
PostPosted: Wed Jan 07, 2015 4:15 pm    Post subject: Reply with quote
TBH I don't activate the mobile sites because they are everywhere. I just get alerts for fixed cameras, specs and redlight.
Hacking is not what is needed as ° camera direction is included in one of the downloadable files but not the one I currently use. The speed zoned set uses compas points which do show up on the banner warning. Just means you have to look at it and know which way your facing.
meditek
PostPosted: Wed Jan 14, 2015 6:11 pm    Post subject: Reply with quote
Kremmen wrote:
Ok thanks
Once you've used it, if you still think a user defined working directory is the way to go I'll work on it.
I'll go further and say :-
1. The program need some work not least as the file name for the free icons download has changed resulting in the user having to do unnecessary work.
2. The user should be able to define :-
a) the input directory/folder
b) the output/folder, as pouring into a possibly huge documents file like mine is very irritating and requires more work cleaning it out afterwards.
If there is a way to do this already then I apologise but there is no help file to turn to.
c) may I suggest a user editable .ini file to simplify the programming.
Otherwise it's a great program saving a lot of messing around
PostPosted: Thu Jan 15, 2015 5:48 am    Post subject: Reply with quote
You are right in that you already can define the 'working folder' from within the program. You can therefore set the location where you store all your camera files as a one off task. I have mine set to D:/PGPSW/ well away from the C drive.
Next step is to unzip the camera files via the programs utility. What was done was the ability to unzip each of the required elements separately if required. In my case I have already configured my preferred wav and bmp files so all I do is unzip just the camera csv files and then process them through.
Each time I collect an updated set of cameras my procedure is:
1) Download camera zip file to D\PGPSW\
2) Unzip just the csv cameras via program
3) 'Process'
4) Run POILoader
Total time, a couple of minutes.
There is a help file, is it not displaying for you?
meditek
PostPosted: Thu Jan 15, 2015 9:36 am    Post subject: Reply with quote
3) 'Process'
4) Run POILoader
Thanks, got the hang of it now. I never spotted the save settings!
PostPosted: Thu Jan 15, 2015 10:04 am    Post subject: Reply with quote
The save settings shouldn't be required as it auto saves these when you exit the program.
from memory these are in your own 'User' area then AppData, Kremmen~, Garmin Converter~, 2013~
tomtompgpsw
PostPosted: Sat Mar 21, 2015 10:54 pm    Post subject: Overspeed wav Reply with quote
Hi there Kremmen, I am new to Garmins this year and just started using your excellent program Garmin CSV to GPX Converter. Having got it all setup all i am missing is the overspeed.wav, I checked your Dropbox link but is not there anymore, is there anywhere else that i can get it from. Thanks
Nuvi 2599LTM-D
PostPosted: Sun Mar 22, 2015 8:30 am    Post subject: Reply with quote
Ah yes, try this:
https://www.dropbox.com/sh/hjik8uwrjhliorz/AAAVcSuJFgyg6GI-Q5fohnCga?dl=0
tomtompgpsw
PostPosted: Mon Mar 23, 2015 5:01 pm    Post subject: Reply with quote
Thanks. Smile
Nuvi 2599LTM-D
PostPosted: Mon Jul 27, 2015 6:48 am    Post subject: Reply with quote
Latest version:
https://www.dropbox.com/s/5ge91yl7neiulu6/CSV%20to%20GPX%20Installer.zip?dl=0
This is a Microsoft Visual Studio 2013 clickonce application.
Unzip the file into its own unique location/folder then run the setup.exe. If you haven't got Microsoft's dot net v4 then it will prompt you to download it and will provide a single click link to do it.
Once run it will place a shortcut on the desktop but the program will not use Windows Installer but will use the latest VS ClickOnce routine and the program file will go to your own user data area. The install is very quick and it does place the uninstall into the Windows Installer list as normal.
Some AV programs will throw questions about do you want to continue even though I've signed it with the strong name technology. Norton initially queried downloading dot net from Microsoft!
PostPosted: Fri Aug 14, 2015 8:39 am    Post subject: Reply with quote
Another update:
After testing the adjacent camera feature I found some of the cameras removed were further away than planned. The maximum distance was 135 yards which I think is too much.
I've found some better code for getting the exact distances between 2 Lat/Long points that is far more accurate.
I've set the default distance as 60 yards as this just exceeds the width of an 8 lane motorway including hard shoulders and central reservation. If 60 yards proves too low then you can adjust it:
DropBox link:
Page 14 of 75
