Pocket GPS World :: View topic - Grid references and GPS
whizzo
PostPosted: Tue Sep 21, 2004 8:19 pm    Post subject: Grid references and GPS Reply with quote
Can anyone tell me how I can convert OS grid references into co-ordinants for my GPS (Garmin 60CS), or recommend software to do this?
I have a rambleing quiz and all the co-ords for the clues are OS grid references. I would like to input all the OS grid refs as way points into my GPS.
Tim Buxton
PostPosted: Tue Sep 21, 2004 8:36 pm    Post subject: Reply with quote
You can change the position format on the 60CS to British Grid, then input your waypoints in that format. See page 64 of the User Manual for details.
Tim
Privateer
Hi Whizzo,
I don’t know the Garmin 60CS. Can you change the Position Format to “British Grid” for the Ordnance Survey Grid References? If you are using it in conjunction with an OS map then you may want to change the Map Datum from WGS84 to ORD SRVY GB, else the position may be out by 100 metres. This is because OS Maps use the ORD SRVY GB Map Datum
If you change the Position Format to “British Grid”, you may find that your quiz quotes 6 figure Grid References (e.g. ST 123 678), when your GPS uses 10 figure Grid References (e.g. ST 12345 67890). Both
Grid References are the same location, although the shorter one is less accurate.
Robert.
Garmin Camper 770 LMT-D
njsb
PostPosted: Tue Sep 21, 2004 8:39 pm    Post subject: Reply with quote
Go to
http://www.gps.gov.uk/
they have a 'coordinate converter' but you have have to register with the site to use it (it appears free to register).
Hope this works.
njsb
icsys
PostPosted: Tue Sep 21, 2004 8:41 pm    Post subject: Reply with quote
Have a look at The Ordnance Survey website I believe they provide algorithms and sample code for converting in both directions on their web site.
Also take a look at www.StreetMap.co.uk, there is provision there to convert coordinates.
Ian.
iPAQ 2210 | Navman 4100 BT Receiver
Navman iCN 635
TomTom GO
Anquet OS mapping
DeeJay
PostPosted: Thu Sep 23, 2004 11:05 am    Post subject: Reply with quote
Other possibilities include, but are not limited to -
WayPoint WorkBench (an eXcel spreadsheet)
http://www.sheps.clara.net/WW.htm
GPS Utility (which also knows how to upload your
converted data into your Garmin)
http://www.gpsu.co.uk
DeeJay
Leicester, UK
e: PktGPS ["AT"] DavidRoberts.Org.UK
nej
PostPosted: Thu Sep 23, 2004 11:55 am    Post subject: Reply with quote
Not the same David J Roberts that used to work in Chessington?
DeeJay
PostPosted: Fri Sep 24, 2004 9:48 am    Post subject: Reply with quote
It is correct to say that this is not the same David J Roberts that used to work in Chessington.
DeeJay
Leicester, UK
nej
PostPosted: Fri Sep 24, 2004 11:52 am    Post subject: Reply with quote
Strange - wonder what the chances of two David J Roberts's working in GPS are!
22.063 (19 Jun 24)
