Pocket GPS World :: View topic - Nissan Connect
Nissan Connect
questy
PostPosted: Thu Jul 31, 2014 10:43 am    Post subject: Nissan Connect Reply with quote
Hi I have a 2014 Nissan qashqui and have been trying to download the speed camera database to the connect sat nav, it recognises my usb says no audio files found and then tells me that poi files will be updated and overwrite existing files, click ok and then it says copying my poi to system, after 30 secs it goes back to map but nothing loaded should I be doing anything else? any help appreciated Thanks
PostPosted: Thu Jul 31, 2014 12:14 pm    Post subject: Reply with quote
Have you tried a different SD card or re downloading the database in case the copy that you have is corrupt in some way?
questy
PostPosted: Thu Jul 31, 2014 1:37 pm    Post subject: Reply with quote
The SD card is supplied with the car I have downloaded your database to a usb "tried several" I have just tried your latest update but still no luck Tim
I now have the problem sorted it appears to be a usb memory card thing first I used a Sandisk 2 gb with no luck then a Sandisk Cruzer 2gb still no good and I just bought a cheep Integral 8gb fron Argos at £4-99 and it works fine.
