Pocket GPS World :: View topic - GPS with "Pulses Per Mile" Output
scrnchr
PostPosted: Fri Jul 18, 2014 12:14 am    Post subject: GPS with "Pulses Per Mile" Output Reply with quote
Hello,
I am configuring a speed control for a wakeboat. I plan to slave the servo to a GPS speed signal. The servo requires an input based on a "Pulse Per Mile" (PPM) stream, and can be set to 2k, 4k, 5k or 8k PPM (where k means thousand, e.g. 8k PPM = 8,000 PPM).
Many of the GPS "pucks" I have found provide output in NMEA 0183 data format or GARMIN proprietary format. It appears to me that both of these provide strings of digital parameters, so I doubt the pulsed stream is supported.
I found these:
JEGS 41612 - 4k, 8k, 16k PPM
Veethree - 8k, 16k PPM
Quick SYNC GPS Pulse Generator - assuming 8k, 16k PPM
It appears that the Nordskog GPS speedo is no longer available (?)
I also found the CruzPro SOG1 which converts NMEA to pulse, but it costs as much as the JEGS or Veethree.
I have these questions:
1. Do any of the handheld GPS units provide an 8k PPM pulsed speed output? Then I would have the nav display rather than just the speed.
2. Can anyone point me to an inexpensive digital speedometer display, something like this old Nordskog display? I would like to tie the GPS pulse signal to a display, if no handheld units provide the pulsed output.
23.082 (13 Aug 25)
