Pocket GPS World :: View topic - Basecamp 4.3.2
Basecamp 4.3.2
PostPosted: Wed Jun 04, 2014 4:55 pm    Post subject: Basecamp 4.3.2 Reply with quote
BaseCamp software version 4.3.2
as of June 3, 2014, available here:
http://www8.garmin.com/support/download_details.jsp?id=4435
◦System Requirements:
Windows Vista Service Pack 2 or later is required. Machines with earlier operating systems can use BaseCamp 4.2.5.
◦.NET framework 4.5 SP1 is required. A current version of .NET will be installed if needed.
◦Windows Media Player 11 or greater is required (a free download from Microsoft).
◦1 GB of system memory is required, 2 GB of system memory is recommended when using BirdsEye Imagery or Garmin Custom Maps.
◦A video card that supports OpenGL version 1.3 or later is needed to enable the 3D view.
◦If you experience problems when interacting with the map views, please make sure that you have installed current video card drivers.
◦BaseCamp will recognize all MapSource products except BlueChart.
◦BaseCamp does not work with serial GPS devices.
Change History
Changes made from version 4.3.1 to 4.3.2:
◦Fixes for several startup issues
◦Fixed error after ejecting a device
◦Fixed the Device Transfer Options page not being enabled
eddieo
PostPosted: Tue Jun 10, 2014 12:10 pm    Post subject: Reply with quote
Hmm.....just downloaded the last one last week, do I just overwrite or remove previous version first please
PostPosted: Tue Jun 10, 2014 12:15 pm    Post subject: Reply with quote
Mine updated just fine without issue but again some users report issues doing it that way. I'd try it and if it doesn't work and you get a .dll error the current Garmin advice is:
Anyone getting a Windows file .dll error message after updating BaseCamp on a Vista, 7, or 8 computer should uninstall BaseCamp then delete the C:\Program Files (x86)\Garmin\BaseCamp folder. Reinstall BaseCamp and the error should not return.
Note it's now up to 4.3.3 Very Happy
eddieo
PostPosted: Fri Jun 13, 2014 11:00 am    Post subject: Reply with quote
I just downloaded new version and seems to have worked OK this time...
22.062 (12 Jun 24)
