caldiboy Occasional Visitor
Posted: Thu Jun 05, 2014 9:29 am Post subject: Add Trip Distance to Montana |
I'm using the Garmin Montana in an off road motorcycle event in Romania this July.
The organisers load a map with a route onto the GPS unit, you simply follow the line and have an allowed time to complete the course.
With that in mind, whilst I'm navigating I'd like the screen to also display the current speed, the time and distance travelled in small boxes - much like the current Navi mode.
I can currently achieve the speed and time but not the distance.
Any information as to how I can add this is much appreciated.
Thanks,
Steve. |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4462 Location: West Sussex
Posted: Thu Jun 05, 2014 9:45 am Post subject: |
Are you using the nuvi dashboard? If so distance travelled is not an option although distance to destination is. |
Posted: Thu Jun 05, 2014 10:26 am Post subject: |
Yes, I'm using the Navi dashboard but I can't see how to get any distance added - if I could get distance to destination that would do.
Perhaps I'm being thick but would it be under speed?
Thanks for the help. |
Posted: Thu Jun 05, 2014 11:16 am Post subject: |
No, it's in the other field, the time one. Just tap it and you'll see the options. |
Posted: Thu Jun 05, 2014 11:29 am Post subject: |
Right, I'll check it tonight when I get in but I'm sure it's not there - elevation and something else is?
Is there any way to add that in should it not be there?
Thanks again. |
Posted: Thu Jun 05, 2014 11:45 am Post subject: |
It's only there when you have an active route, otherwise you only get time, elevation and direction of travel. |
Posted: Thu Jun 05, 2014 12:38 pm Post subject: |
sussamb wrote: | It's only there when you have an active route, otherwise you only get time, elevation and direction of travel. |
Aha! Maybe that's my problem, I'll check it out this evening.
Thanks very much. |
M8TJT The Other Tired Old Man
Posted: Thu Jun 05, 2014 3:02 pm Post subject: |
How on earth can you expect to have a distance to destination without a route set?  |
Posted: Fri Jun 06, 2014 9:41 am Post subject: |
M8TJT wrote: | How on earth can you expect to have a distance to destination without a route set?  |
If you read from the top I wanted to able to set a trip distance - not necessarily a distance to destination. |
Posted: Fri Jun 06, 2014 9:44 am Post subject: |
Thanks very much - gave it a try last night and you were right, there are additional options available when navigating.
The distance to destination should work for what I need! |
