Pocket GPS World :: View topic - Switching Map Regions (3598)
walkerx
PostPosted: Wed May 28, 2014 7:15 pm    Post subject: Switching Map Regions (3598) Reply with quote
Has anyone tried to switch map region on the 3598
If I choose this it says that the region you have selected does not support voice-activated navigation
Bit silly when selecting any of the regions it says the same thing and tells you to install the full coverage of europe.
I've selected the UK & Ireland option just to see if it fixes the grey blocks on screens (doubtful but you never know)
well that didn't work as you still get the grey blocks and you can't find places so the voice search is removed for British English
Davidonly
PostPosted: Thu May 29, 2014 7:15 pm    Post subject: Reply with quote
Same issue here so would like to know what's going on. The new mapping exceeds the memory of my unit / SD card. Only had it 3 months!
Going to a selected regional update brought up the same warning as the OP has found.........
PostPosted: Thu May 29, 2014 8:02 pm    Post subject: Reply with quote
Afraid that's the way it is, see this FAQ https://support.garmin.com/support/searchSupport/case.faces?caseId=%7B1df288e0-19f9-11e0-d39a-000000000000%7D
The answer is just to install a 8Gb sd card ... then memory space isn't an issue.
walkerx
PostPosted: Sat May 31, 2014 12:58 am    Post subject: Reply with quote
and if you are not careful the update is removing audio files as done this on the replacement 2598 i've got
PostPosted: Sat May 31, 2014 5:32 am    Post subject: Reply with quote
I wonder why it would remove audio files ?
Satnav:
Car Average MPG :
PostPosted: Sat May 31, 2014 6:09 am    Post subject: Reply with quote
So do I ... but it was a bug a while back which seems to have been reintroduced. Hence the advice back up first Wink
If they've gone either restore them from a back up or click the Device tab in Express, scroll down to the Add additional voices and select British English.
PostPosted: Sat May 31, 2014 5:33 pm    Post subject: Reply with quote
I did notice there was a Serena update on the same day as my 2015.10
I wonder if GE tries to remove anything it can if deems there isn't enough room?
Satnav:
Car Average MPG :
PostPosted: Sat May 31, 2014 5:35 pm    Post subject: Reply with quote
Well that's the idea ... but it's meant to offer you the choice of whether you want to delete voices ... seems it's no longer doing that with this version (3.2.4).
Don't be surprised to see a new version out shortly Wink
